► APEX | New Forged Sprint™ Line - Lightweight Motorsport Wheels For Your Civic Type-R
APEXRaceParts
BMW
11th Gen Honda Civic ► APEX | New Forged Sprint™ Line - Lightweight Motorsport Wheels For Your Civic Type-R fl5_ctr_vs5rs_3_14_2023.00_00_45_09.Still023
Introducing APEX Forged Sprint Line
For Your FL5 Civic Type-R
Our forged Sprint™ line was built to be extremely light while still offering a meaningful strength increase over our flow formed wheels. Engineered for drivers looking to shed as much weight as possible to improve lap times.
➡︎ 10K ton forged 6061-T6 aluminum
➡︎ Stronger Sprint™ spec inner lip
➡︎ Side-milled spokes for reduced weight
➡︎ Massive brake clearance
➡︎ Unmatched replacement program
➡︎ Lifetime structural warranty
➡︎ Independently tested and certified
VS-5RS Fitments:
FitmentFinishWeightMSRP
18x9.5" ET45​
Anthracite, Brushed Clear, Motorsport Gold
Satin Bronze, Satin Black​
18.2 lbs​
$649​
18x10.5" ET47​
19.0 lbs​
$669​
19x9.5" ET45​
19.1 lbs​
$779​
<<< Click here to visit our website >>>
10K Tons Of Pressure
11th Gen Honda Civic ► APEX | New Forged Sprint™ Line - Lightweight Motorsport Wheels For Your Civic Type-R 10KPressure-cro
Our new forgings weigh as much as 120 pounds before machining. To form such a thick blank we require special equipment capable of 10,000 metric tons of pressure. This extreme pressure increases the strength of the aluminum by eliminating porosity and improving the grain structure.
True Motorsport Blanks
11th Gen Honda Civic ► APEX | New Forged Sprint™ Line - Lightweight Motorsport Wheels For Your Civic Type-R TrueMotorsportBlanks-b
Many companies use 3rd-party blanks intended for non-motorsport wheels which can severely limit sizes, concavity, spoke design, and critical brake clearance. We designed our very own blank profiles from scratch which gives us total control over the final product, resulting in exceptionally deep spokes and stronger designs.
Learn more about our true motorsport blanks.
Side-milled Spokes
11th Gen Honda Civic ► APEX | New Forged Sprint™ Line - Lightweight Motorsport Wheels For Your Civic Type-R EC-7RS_spokes%20copy
11th Gen Honda Civic ► APEX | New Forged Sprint™ Line - Lightweight Motorsport Wheels For Your Civic Type-R VS-5RS_spokes%20copy
One of the most significant upgrades to our Sprint wheels is the addition of wider and deeper side-milled spokes. Any excess material that doesn’t add strength is carved out using a precision CNC ball cutter. Side-milling is often deemed cost-prohibitive by others, but for true performance without compromise we believe it's essential.
➡︎ 40-50% Wider
➡︎ 50-100% Deeper
Learn more about our wider and deeper side-milling.
A Stronger Lightweight Wheel
Our forged Sprint™ wheels are lightweight without the strength compromises found on typical lightweight wheels. First, we carved out as much material as possible, then we purposefully added one pound back to reinforce critical areas, creating a stronger inner lip and a higher load rating.¹ What’s the point of a lightweight wheel if it’s fragile?
Weight Optimized
11th Gen Honda Civic ► APEX | New Forged Sprint™ Line - Lightweight Motorsport Wheels For Your Civic Type-R 42229115900_eb8444a578_z
We conducted extensive Finite Element Analysis (FEA) to reinforce high-stress areas and to remove material where it didn’t improve strength. The result is a wheel that is exceptionally light without the strength compromises found on typical lightweight wheels.
Independently Tested
11th Gen Honda Civic ► APEX | New Forged Sprint™ Line - Lightweight Motorsport Wheels For Your Civic Type-R STL-radial-test-logo
[/size]
We don't rely solely on computer simulations or unverifiable in-house testing. We believe independent testing is critical to protect consumers in this unregulated industry. We chose STL, an independent lab in Ohio, to test our Sprint™ wheels far above JWL standards, including increases in testing duration, impact drop height, and total load.
Learn more about our rigorous independent testing.
Tough Inner Lip
11th Gen Honda Civic ► APEX | New Forged Sprint™ Line - Lightweight Motorsport Wheels For Your Civic Type-R Sprint-Lip-Comparison-1200
Introducing the Sprint™ spec inner lip, with a unique channel profile that makes it even stronger than our previous designs. So even though our Sprint™ wheels are pounds lighter than comparable flow formed wheels, the inner lip is 32% stronger.
Learn more about our Sprint™ spec inner lip.
Big Brake Clearance
11th Gen Honda Civic ► APEX | New Forged Sprint™ Line - Lightweight Motorsport Wheels For Your Civic Type-R VS-5RS_brake_clearance
From day one, APEX has been on a mission to build wheels that clear big brakes. Our new forged wheels are the product of everything we’ve developed over the past 10+ years, including an innovative high-clearance barrel design and vehicle-specific spoke profiles.
Deeper Concavity
11th Gen Honda Civic ► APEX | New Forged Sprint™ Line - Lightweight Motorsport Wheels For Your Civic Type-R VS-5RS_concavity
Our new forgings were redesigned to create extra deep, concave spoke profiles. Their new shape allows us to make any profile, from flat to deep and everything in between. Each one is optimized for a specific application using 3D laser scans of factory and aftermarket brake kits.
Paintless Knurled Beads
11th Gen Honda Civic ► APEX | New Forged Sprint™ Line - Lightweight Motorsport Wheels For Your Civic Type-R 48544933791_8bee5c58e8_z
Whether it's a day at the track or months of street driving, repeated hard braking and acceleration can make a tire slip along the bead seat and go out of balance, causing vibration. Knurled beads help, but are less effective when painted over. Our forged line features unpainted knurled beads that stay sharp and maximize grip.
Learn more about why our forged wheels have unpainted knurled beads.
Built for impact sockets
11th Gen Honda Civic ► APEX | New Forged Sprint™ Line - Lightweight Motorsport Wheels For Your Civic Type-R VS-5RS_impact_socket
Track wheels need track tools. Don’t settle for wheels that require undersized tuner lugs or thin walled sockets. All APEX wheels accommodate over-sized race lugs and impact sockets to make swapping wheels lightning fast.
11th Gen Honda Civic ► APEX | New Forged Sprint™ Line - Lightweight Motorsport Wheels For Your Civic Type-R 3-sockets
Laser-Engraved Specs
11th Gen Honda Civic ► APEX | New Forged Sprint™ Line - Lightweight Motorsport Wheels For Your Civic Type-R EC-7RS_laser
As track enthusiasts ourselves, we know how frustrating it is to try to locate and decipher wheel specs that have been hastily hammered into the rim or become unreadable over time. With our new Sprint™ wheels, we chose to invest a little extra and laser-engrave the specs on the barrel, in plain sight, making them easy to find and read. (You’re welcome.)
Lifetime Warranty
All APEX wheels come with a lifetime structural warranty against defects in workmanship and materials, plus a 1 year finish warranty. Exchanges are fast, easy, and hassle-free.
Learn more
APEX Wheel Replacement Program
11th Gen Honda Civic ► APEX | New Forged Sprint™ Line - Lightweight Motorsport Wheels For Your Civic Type-R 48915214281_d13453c6bb_o
Curb rash or pothole damage on the street? Make an oopsie at the track? We’ve all been there. APEX is proud to offer 50% off replacement wheels, no matter the damage.
Learn more
A Fitment For You
11th Gen Honda Civic ► APEX | New Forged Sprint™ Line - Lightweight Motorsport Wheels For Your Civic Type-R Fitment-for-you
We’ve tirelessly test-fitted hundreds of setup combinations in order to provide direct-fit, spacer-free wheel packages for everything from showroom-fresh cars to all-out race builds. Our detailed fitment guides help you avoid costly trial-and-error and walk you through every step of finding your perfect setup.
Explore our FL5 Civic Type-R Fitment Guide
Questions?
Call: 925-245-0773
Email: [email protected]
Web: www.apexraceparts.com
Hours: M-F 9a-5p PST​
Tickle
Welcome.
I am looking forward to a forged version of your 10 spoke wheel for the FL5.
APEXRaceParts
APEXRaceParts
BMW
On your website you show an 18x9.5 et 58 does that fit/clear calipers?
Great question! Our 18x9.5" ET58 wheels are actually intended for BMW chassis. Because of this, most of them do not clear the FL5 CTR brakes without spacers.
Our Flow Formed EC-7 18x9.5" ET58 however is the exception to the rule and clears the factory FL5 brakes with no spacer required. Our flow formed fitments are listed in a separate flow formed thread.
Hope this clears things up!
APEXRaceParts
APEXRaceParts
BMW
Quick update for everyone.
11th Gen Honda Civic ► APEX | New Forged Sprint™ Line - Lightweight Motorsport Wheels For Your Civic Type-R 52574056976_402d1046c6_b
We've launched our FL5 Civic Type-R Fitment Guide!
If you haven't seen one of our fitment guides before, it's a great way to get an idea of what fits, what mods are needed to make it fit, what clears brakes, and more! Hope you all find this beneficial and if you have any questions the guide doesn't answer, please don't hesitate to get in touch with us directly!
APEXRaceParts
APEXRaceParts
BMW
@APEXRaceParts
Any news or ETA for the SM-10RS for the FL5? Your website's suggested wheel size isn't something I would be interested in. Would prefer something 18x9.5.
Apologies for that listing. The new site pulled over some incorrect information for some of our supported chassis, FL5 included.
Those 18x9" ET30s are not something we intend to offer for this vehicle at all.
We'll have an update for you all within the next couple of days.
APEXRaceParts
APEXRaceParts
BMW
11th Gen Honda Civic ► APEX | New Forged Sprint™ Line - Lightweight Motorsport Wheels For Your Civic Type-R 52760665143_f10e4ed146_b
With having recently announced our new VS-5RS for Civic Type-R, we wanted to take the opportunity to share some of the details and benefits of these new fitments:
18x9.5” ET45: A fantastic dual-duty street or track fitment for the FL5 Civic Type-R that offers a smaller diameter wheel than stock. The ET45 offset brings the wheels flush to the fender without poke. On top of weight savings compared to the OEM 19” wheels, this fitment also allows for great brake clearance.
19x9.5” ET45: A great OEM replacement wheel that allows for reuse of the factory tires. This fitment is intended for those who want a lighter wheel with a more flush fitment than stock.
18x10.5” ET47: An aggressive track oriented fitment for those who are chasing that last nth of a second and don’t want to leave any performance on the table. For those seeking to run 285 or 295 tires up front, this fitment is for you. This is a direct fit option for the FL5 chassis.
One of our current goals here at Apex is to increase our offerings for JDM specific chassis like the Civic Type-R. We feel like we're off to a great start. We also feel the best way to ensure we meet the community's needs is to ask the community what they want. With that, we're running a short poll as an opportunity to get community feedback for upcoming projects!
Vote Here
Questions?
Call: 925-245-0773
TJ83
TJ
Guam
2023 Type R CBP
Wanted to post pics of my new VS-5RS in Bronze finish. I'm not much of a photographer so please excuse the pics lol.
Wheel specs- 18x10.5 et47
Tires - Yokohama Advan Sport V105. 285/35 r18
11th Gen Honda Civic ► APEX | New Forged Sprint™ Line - Lightweight Motorsport Wheels For Your Civic Type-R 20231209_074638
11th Gen Honda Civic ► APEX | New Forged Sprint™ Line - Lightweight Motorsport Wheels For Your Civic Type-R 20231209_081924
11th Gen Honda Civic ► APEX | New Forged Sprint™ Line - Lightweight Motorsport Wheels For Your Civic Type-R 20231209_081935
