sonicgreysi
- Thread starter
- #1
Looking for Any clutch,Retro fit for my 11th Gen Si.Ran Ktuner 21 psi and Noticed Slipping right around 3000 rpms.Websites and Links appreciated
Having the same issue, 5th and 6th gear at 3000k..Looking for Any clutch,Retro fit for my 11th Gen Si.Ran Ktuner 21 psi and Noticed Slipping right around 3000 rpms.Websites and Links appreciated
asked him about it they have no idea when a stage 2 will be in stock all they have is stage 3Having the same issue, 5th and 6th gear at 3000k..
just babying it for now, I know axion industries has a stage 2
Does the rv6 retro flywheel kit work on the 11th gen si?I got a bunch of Rv6 retro flywheels arriving next week and Exedy stage 1 clutch in stock
Yes it does, I am running Emans retro fit clutch. All the 10th gen clutches work exact same trans. www.axionind.comDoes the rv6 retro flywheel kit work on the 11th gen si?
depends on the state of the flywheel, the sort of situation where you won’t know until you pull it apart.With the 22 Si having a single mass flywheel, is it necessary to change the flywheel when moving to an aftermarket clutch? I was considering getting an ACT clutch and my Si would be fairly low miles (<10,000) by the time I pull the trigger. Only plans are intake, DP, FP, exhaust, intercooler and flex fuel. Not trying to go crazy, just wanna stay reliable. Any input would be appreciated!
https://stores.axionind.com/exedy-f...-1-5t-retro-flywheel-with-oe-release-bearing/The stock clutch shows slipping even with tunes and no other bolt ons, best to get it out of the way so you run into no issues. ACT are about an average of 6 month wait. I have the rv6 flywheels and exedy clutch coming in which is a great option, since thats pretty much what we are running with no issues and will hold any power you throw at it
