Anyone add the Canadian fogs to the US version?
Doublestack00
GA
1994 Honda Acty
If so what did it take to add them? Wiring already in place?
Integra23
2023 Integra 6spd A-Spec
ThunderPigeon
Long Island
2022 Crystal Black Pearl Civic SI
Wiring is not already in place unfortunately. Keep in mind, certain places will require the fog lights turn off with the high beams or you will fail inspection and the harness with the button does not accomplish that. You may want to look into that before ordering anything.
Doublestack00
Doublestack00
GA
1994 Honda Acty
GA doesn't do any visual inspection at all.
I would probably opt for the additional $80 OE stalk switch though.
Shankmeyster
AZ
23 Si
What I really want to know is if we can PnP the digital dash from the Canada car after getting the odo set. :hmm:
AshSerigala
11-Gen Honda Civic Hatchback Sport-Touring
I just installed these a couple days ago. Works great. I skipped installing the switch and left the lights on Auto.
Are these the"laser foglights"mikstore sells? My car came stock with foglights, so I was able to just plug-and-play the laser fogs. I just had a question or two if you're running the same!
Sidian
James
Miami, FL
Yes these are the “Civic 22-23 Laser Projector Fog Lamp”
Integra23
What's up with the "Rear" switch?
They have two options. Stalk upgrade like factory or a cheaper version with a switch you mount in a blank on the dashboard.
Zayzayy
Xavier
Louisiana
10th gen si
Where did you connect the wires in order to have them auto
ThunderPigeon
Long Island
He means the rear setting on the Mikstore stalk. That Stalk is the over seas stalk. The NA stalk only has a single switch for the fogs. They have rear fogs in other locales. You can get the NA OEM fog light stalk for significantly cheaper than the Mikstore option.
