Auto Idle Stop not working '22 Si
KevCarver
Kevin
Knoxville, TN
'22 Civic Si
Seemingly was working fine since I picked up the car, but on Thursday (2 weeks exactly since I got it) it stopped. The message comes up that it is temporarily disengaged due to warmup/charging despite driving for enough time to have a fully charged battery and warmed up engine. I drove it up to 30 minutes a couple times. Measured the battery voltage this morning after sitting all night and it was 12.5 or 12.7, can't remember exactly. Running at idle and warm this afternoon is was 14.48. I've seen it shut off for those legit reasons the past two weeks, and also for climate control, but I keep trying it with CC off and still not working. I can manually turn the system off and on with the button, but that makes no difference when it is set to on.
I know most of you would be happy about this, but if there is a sensor error in the car it needs to be fixed. I am getting no CELs or any warnings of anything amiss. Plus, this is my first car with this system and I'm not convinced either way yet.
Is anyone else having an issue?
zeroptzero
Joey
Ontario Canada
Yesterday my engine shut down on auto stop, within 5 seconds it restarted on its own for no apparent reason. I wish it just wouldn't shut down rather than doing that, it can't be that efficient if it restarts seconds after shutting down.
KevCarver
KevCarver
Kevin
Knoxville, TN
'22 Civic Si
I've had that happen, message was climate.
Bunhyung
Benjamin
Maine, USA.
'22 CBP ST
This is from page 470 of the owners manual
ā– Auto Idle Stop may not activate when:
ā€¢ The vehicle is stopped by braking suddenly.
ā€¢ The steering wheel is operated.
ā€¢ The vehicle is repeatedly accelerated and decelerated at a low speed.
ā€¢ The fan speed is high.
ā€¢ The climate control system is in use, and there is a significant difference between
the set temperature and the actual interior temperature.
ā€¢ The climate control system is in use, and humidity in the interior is high.
ā€¢ Altitude is high.
Bunhyung
Benjamin
Maine, USA.
'22 CBP ST
And from page 469
Auto Idle Stop activates when:
The vehicle stops with the transmission in (D and the brake pedal depressed.
When you put the transmission into (P quickly with depressing the brake pedal, the
Auto Idle Stop continues to operate, even if the brake pedal is released.
If you depress the brake pedal, the engine may automatically restart.
ā– Auto Idle Stop does not activate when:
ā€¢ The Auto Idle Stop OFF button is pressed.
ā€¢ The driverā€™s seat belt is not fastened.
ā€¢ The engine is not adequately warmed up or coolant temperature is high.
ā€¢ The transmission fluid temperature is low or high.
ā€¢ The vehicle comes to a stop again before the vehicle speed reaches 3 mph (5 km/
h) after the engine starts.
ā€¢ The vehicle is stopped on a steep incline.
ā€¢ The transmission is in a position other than (D.
ā€¢ The engine is started with the hood open.
u Turn off the engine. Close the hood before you restart the engine to activate
Auto Idle Stop.
ā€¢ The battery charge is low.
ā€¢ The internal temperature of the battery is 41Ā°F (5Ā°C) or less.
ā€¢ The climate control system is in use, and the outside temperature is below āˆ’4Ā°F
(āˆ’20Ā°C) or over 104Ā°F (40Ā°C).
ā€¢ The climate control system is in use, and the temperature is set to Hi or Lo.
ā€¢ is ON (indicator on).
ā€¢ The drive mode is in the SPORT mode.
ā– Auto Idle Stop Activates When: 1Auto Idle Stop Activates When:
Do not open the hood while the Auto Idle Stop
function is activated. If the hood is opened, the
engine will not restart automatically.
In this case, restart the engine with the ENGINE
START/STOP button.
2 Starting the Engine P. 448
When Adaptive Cruise Control (ACC) with Low
Speed Follow is in operation, the vehicle stops
without depressing the brake pedal and Auto Idle
Stop may activate. In such cases, the engine may
restart if you change the shift position other than (D.
Pressing the ENGINE START/STOP button causes
the engine to no longer restarts automatically. Follow
the standard procedure to start the engine.
Models with drive mode switch
KevCarver
KevCarver
Kevin
Knoxville, TN
'22 Civic Si
Thank you for the reply. I understand the parameters under which the system is disabled. It's my belief the when the car meets the proper circumstance to enable the system, it is not functioning and displays the message that it needs charging or warming. I have, over the first 2 weeks of ownership, witnessed the system functioning properly, not since Thursday however.
jsocks014
WV
11 Nissan Titan Pro-4x
Itā€™s a brand new car, take it to your dealer and have them troubleshoot if you suspect a malfunction. Get a free car wash for your troubles of having to make a special trip.
KevCarver
KevCarver
Kevin
Knoxville, TN
'22 Civic Si
Took it to the dealer yesterday, after quite a long time spent with it, they agree it should be working and wanted more time to find out why it isn't. No fault codes show up. I'm in a rental for the moment...
KevCarver
KevCarver
Kevin
Knoxville, TN
'22 Civic Si
Dealer said the battery was the problem. I read a several year old post on an Odyssey forum saying the same thing. He had several batteries installed. Dunno, it's better than a CVT Corolla rental! I guess I'll just start turning it off and not worry about it...
JQ42
Jeff
Orlando
Civic Sport Hatchback
So can we not have the ac on and auto stop on? I live in florida where the AC is needed 24/7 and notice it only works when I have the AC off.
zeroptzero
Joey
Ontario Canada
Well yeah, it can work with the A/C on but the parameters don't work so well with Florida weather, the difference between outside and inside temps, the humidity, etc. and other factors don't seem to allow it to work very much in hot Florida temps. Maybe on those rare cool days down there. It is like the auto-stop not working often in frigid Canadian winter weather, quite often it won't work here when it is too cold, same effect but totally different weather but with similar parameters calling the shots.
KevCarver
KevCarver
Kevin
Knoxville, TN
'22 Civic Si
Update pt2!
It's been working properly since I got it back from the dealer until Saturday. I had the car on with the engine off in the garage listening to music for a bit and decided to top off the battery with my Battery Tender. For whatever reason, that causes the AIS to show the message of needing to warm up or charge. I can't imagine why this is, but it is. I disconnected the negative terminal for a couple minutes and today it works. I'm sure this is what caused the issue in the first place.
Shankmeyster
AZ
23 Si
This was one of the worst tech decisions on Honda's part. Annoying af and I'm guessing it cuts the starter/battery life down drastically on a vehicle that already has horrible batteries to begin with.
KevCarver
KevCarver
Kevin
Knoxville, TN
'22 Civic Si
Thatā€™s why I canā€™t understand why having it on a tender disables the system.
