Brake maintenance with OBD scanner
Ic@ns33urhrt
Southeast
A car
Help! I put the car in brake maintenance with the OBD scanner, but when I put the new pads in the caliper would not fit around the pads. Now, the old pads were worn pretty bad. Could the e- brake not have retracted all the way? Because the pads were so worn. Any input is appreciated. Thanks.
Ic@ns33urhrt
Southeast
A car
Did you push the piston back? You still have to do that after retracting the EPB. It’s ok to push straight back, no need to rotate while compressing
I really like how thorough this video is:
Civic Type R Rear Brake Change Tutorial Video Link
Thanks for the reply. I tried pushing the piston back but it would not budge. I thought the scanner would retract it fully. May have to grab a tool to push that piston back in.
ender_ong
Andrew
East Bay, CA
18 Ridgeline RTLE white/black, 24 DE5 white/black
Yeah, the scanner (or rotating the spindle manually if no scanner) retracts the parking brake, but has no effect on the hydraulic brake line, hence however far in the caliper piston is based on pad wear, it will remain that way until physically compressed
ender_ong
Andrew
East Bay, CA
Either that one or the upgrade, AP2500E
