Buddy Club 17-18 Civic Hatchback Sport Spec Damper Coilovers
kseriesparts
Colorado
https://www.kseriesparts.com/merchant.mvc?Store_Code=CR&Screen=PROD&Product_Code=BCS-BC02-SSHFK2
BUDDY CLUB 17-18 CIVIC HATCHBACK SPORT SPEC DAMPER COILOVERS
PART NUMBER: BC02-SSHFK2
Be the first to review this product
$1,013.58 & FREE SHIPPING
Starting at $90/month with Affirm. Learn More
11th Gen Honda Civic Buddy Club 17-18 Civic Hatchback Sport Spec Damper Coilovers BC02-SSHFK2
  • The Single Tube Design of the Buddy Club Sport Spec Damper allows for use of a larger piston than other designs, this allows for better handling and a smoother ride.
  • The inner pistons of Buddy Club Sport Spec Dampers are precision machined to the tightest tolerances possible to prevent unnecessary noise and vibration.
  • Within normal operating range, simply use the spanner wrenches (provided in the damper kit) to adjust the lower bracket of the damper to your desired vehicle ride height, without sacrificing comfort or performance.
  • Inverted Designed Dampers for MacPherson Strut equipped cars allow for a larger piston and more fluid movement than conventional designed dampers adapted for Macpherson use.
  • All Sport Spec Dampers have 20 levels of damping and rebound adjustability. By simply turning the knob on the damper, you can adjust the damping and rebound settings to accommodate your own driving style.
