GarageLine.com: Civic Si & Sport Wheel Spacers
GarageLine.com
Jermaine
Gaithersburg, MD
www.garageline.com
Golf R, 17 si, 15 M3
GarageLine.com: Wheel Spacer Packages (15mm, 20mm, 25mm)
11th Gen Honda Civic GarageLine.com: Civic Si & Sport Wheel Spacers 679
20/25 Combo Installed:
11th Gen Honda Civic GarageLine.com: Civic Si & Sport Wheel Spacers IMG_7814-732x488
More Images Here:
http://www.garageline.com/blog/new-product-2017-honda-civic-si-wheel-spacers/
MSRP: $220 for a set of 4
Intro Price: $195
https://garageline.com/honda/280-22...-spacer-combo.html#/29-spacers_size-20mm_pair
Our spacers are built to last, made from 6061 Aluminum and anodized black not only for the cool look but for corrosion resistance. All of our spacers are hubcentric so they have the proper hubsize and are guaranteed not cause a vibration at speed like other cheaper spacers. We use Grade 10 bolts like your stock wheel studs so they are strong as OEM equipment. They do no require extended studs or cutting your stock studs.
100% Bolt on!
[email protected]
240-516-8863
hawk02
Far away
2017 Civic Si Coupe
How safe are these to run and is there more to them besides looks? Improvement in handling? They do look very well built
GarageLine.com
GarageLine.com
Jermaine
Gaithersburg, MD
www.garageline.com
Very safe, we have used our spacers in autox and other HPDE events. Typically you notice a difference with turn in on most cars and theoretical stability as it does make the car wider. I personally think in the looks department it is one of the easiest but best things you can do to make the stock wheels look better.
Thanks,
Jermaine
hawk02
Far away
2017 Civic Si Coupe
T
Thanks,
Jermaine
Thanks for the info. Any recommendations for oe wheels on a 17 hatchback sport that i will be lowering with eibach pro springs that won't interfere with the fenders? Don't want any rubbing, thanks
GarageLine.com
GarageLine.com
Jermaine
Gaithersburg, MD
www.garageline.com
T
20mm should work fine.
Yungfk7
Brandon
1844 E Lomita AVE
2017 honda civic hatchback sport
Will these fit the civic hatchback?
Do you think they'll rub because my car has a 2 inch drop
eDUB632
eDUB
SoCal
2017 Hatchback TOURING
@garageline for the fk7 is the rears 25mm or 20mm? I Noticed the si has wider in the rears , same goes with the hatch?
Keeping my touring rims for the time being and lowering on a PRO-KIT in the near future.
GarageLine.com
GarageLine.com
Jermaine
Gaithersburg, MD
www.garageline.com
Yes we are running the 20mm in the front and 25mm in the rear.
