Backmarker
- First Name
- Phillip
- Joined
- May 16, 2023
- Threads
- 9
- Messages
- 27
- Reaction score
- 88
- Location
- Richmond, Va
- Vehicle(s)
- 2023 FL5
- Thread starter
- #1
Hi folks…
So about a year ago I ran a head to head test of tunes you can buy for a stock car. The results of that test can be found here:
https://www.civicxi.com/forum/threa...ming-soon-updated-with-interim-results.52932/
Dyno chart from then:
The key learnings from that were:
- TSP and Phearable are very similar to each other.
- Both produce way more power than stock
- Quality of gas matters a lot. Both TSP and Phearable tunes had meaningful knock above 6k which pulled timing and limited peak power. This was on 93 octane.
So determined to try and get a clean read I went BACK to the dyno again to do the test again. This time I added a track-focused tune from Jester Tuned. To try and keep a clean read I used 93 octane from a different supplier this time AND I added an octane booster. I was going to use a gallon of E85 but could not find it near the dyno.
Caveat: These are results from a single car on a single day. Your mileage may vary.
Here is the results of round 2:
Once again knock was an issue above 6K rpm suggesting that a) these tunes are sensitive to fuel quality above 6k and b) 93 octane in Va sucks (remember I had added an octane booster). Peak horsepower for TSP and Jester was limited by knock retard.
There was a very small amount of knock on one cylinder with JesterTuned. TSP had more significant knock on two cylinders. Phearable had none. I ran 3 pulls each and picked the best result that was backed up. I also reran Phearable and Jesters again at the end to confirm the results and they were consistent with the first time.
- the Phearable tune appears to be the most conservative with timing and the only one without any knock. It previously was nearly identical to TSP when I ran this last year so I am guessing the performance difference was a fluke.
My conclusions:
- Objective dyno performance comparisons are hard - even when being as scientific as possible.
- All three of these tunes are solid options that will create loads more power than stock. I have had good experience with all three - and received good advice from all three. I have run all three tunes on my car and would feel totally comfortable running any of them long term. IMO A Hondata and one of these tunes is hands down the first mod people should do. They transform the car.
And for me… this story ends here. I put this together as a way to share back with the community. I have spent $1000+ on dyno time just to be able to share as I have known all along I would be modding the car - and that process starts soon. So take from it what you will.
Personally - I have run all three tunes extensively. I now run the JesterTuned tune and plan on him tuning the car as it goes under the knife. . Not because it made a bit more power… I actually expected it to make less. But I enjoy driving the car with his tune in it the most. I appreciate his willingness to develop a track day focused tune (vs peak hp) and his tuning philosophy seems well aligned to my goals. Does not hurt he has the patience of a saint putting up with my dumb and persistent questions.
You can’t go wrong with any of them. Don’t think I could own the car without a tune from one of them. All three tuners are great and I buy most of my parts from TSP
Thanks all!
- Phillip
My conclusions:
Thanks all!
- Phillip
