PRL Motorsports
Premium Performance Products
Export, PA
prlmotorsports.com
2017 Civic Si, 2016 Civic EX-T, 2018 Type R
11th Gen Honda Civic PRL Motorsports 11th Gen Civic 1.5T Front Pipe Development 218060995_199075688899622_1301718681992330279_n
Over the past few weeks our engineers have used our 3D scan data to develop a downpipe and front pipe upgrade for the 2022 Honda Civic 1.5L Turbo. We were able to put together a street downpipe with high-flow catalytic converter, utilizing cast 304 stainless steel upper and lower pieces that allow customers to retain use of the factory heat-shield. The community can expect some big news regarding this downpipe coming soon.
11th Gen Honda Civic PRL Motorsports 11th Gen Civic 1.5T Front Pipe Development FP3
11th Gen Honda Civic PRL Motorsports 11th Gen Civic 1.5T Front Pipe Development FP2
11th Gen Honda Civic PRL Motorsports 11th Gen Civic 1.5T Front Pipe Development FP1
11th Gen Honda Civic PRL Motorsports 11th Gen Civic 1.5T Front Pipe Development IMG_2531
11th Gen Honda Civic PRL Motorsports 11th Gen Civic 1.5T Front Pipe Development IMG_2532
11th Gen Honda Civic PRL Motorsports 11th Gen Civic 1.5T Front Pipe Development IMG_2533
11th Gen Honda Civic PRL Motorsports 11th Gen Civic 1.5T Front Pipe Development IMG_2534
11th Gen Honda Civic PRL Motorsports 11th Gen Civic 1.5T Front Pipe Development IMG_2535
11th Gen Honda Civic PRL Motorsports 11th Gen Civic 1.5T Front Pipe Development 226207410_521228689096084_6171500380513672558_n
A 3D printed front pipe has been fitted to the vehicle to test fit clearance and desired fitment. Now that fitment has passed inspection, we are test fitting a production-level prototype utilizing our new mandrel bent 3.00″ 16 gauge 304 stainless steel tubing, premium interlocking flex bellow section and 304 stainless steel CNC machined flanges.
We hope to have this all into production within the next few weeks, stay tuned for more details!
http://prlarmy.com/Blog/11th-gen-civic-downpipe-front-pipe-development-part-1/
PRL Motorsports
PRL Motorsports
Export, PA
prlmotorsports.com
11th Gen Honda Civic PRL Motorsports 11th Gen Civic 1.5T Front Pipe Development Downpipe-1
11th Gen Honda Civic PRL Motorsports 11th Gen Civic 1.5T Front Pipe Development Downpipe-2
11th Gen Honda Civic PRL Motorsports 11th Gen Civic 1.5T Front Pipe Development Downpipe-3
11th Gen Honda Civic PRL Motorsports 11th Gen Civic 1.5T Front Pipe Development Downpipe-4
11th Gen Honda Civic PRL Motorsports 11th Gen Civic 1.5T Front Pipe Development 241290682_742613449861769_8069174905874126934_n
PRL Motorsports is proud to announce our direct partnership with G-Sport Emissions Systems Powered by GESi. We have been working behind the scenes for many, many months, in an effort to change the downpipe game for the Honda community. Recently, the stars have aligned, allowing us to implement GESi/G-Sport’s 400 CPSI, catalytic converter in our new 11th Gen Honda Civic 1.5L Turbo High Volume Downpipe assembly.
11th Gen Honda Civic PRL Motorsports 11th Gen Civic 1.5T Front Pipe Development GESi-GSport-Logo-Web
11th Gen Honda Civic PRL Motorsports 11th Gen Civic 1.5T Front Pipe Development HighVolume_Logo
What is CPSI?
  • CPSI, or Cells Per Square Inch, are used to measure how much catalyst material is used in a catalyst substrate. The lower the CPSI rating, the less restrictive the catalytic converter. For example, a catless downpipe would have a 0 CPSI rating. However, a lower CPSI rating also means a catalyst with low effectiveness. A higher CPSI means a more effective catalyst. A 200 CPSI cat will have holes 2x the size of a 400 CPSI cat.
What are the benefits of this GESi/G-Sport catalytic converter?
  • All of our PRL Motorsports downpipe assemblies for the Honda 1.5L Turbo will utilize a 4.50” OD 400 CPSI (500-850 HP calculated by GESi/G-Sport) catalyst body, in comparison to our previously used 4.00” OD 300 CPSI (350-500 HP rated) catalyst body. Using to A=Ď€r2 calculate the cross sectional area of the catalyst body, we can see that a 4.00” diameter cat has a cross sectional area of 12.57 sqin and a 4.50” diameter cat has an area of 15.90 sqin, which is a 27% increase. Our new assemblies will be the highest flowing, least restrictive downpipes on the market that will not require any type of ECU calibration or tuner for installation. Because of this increased flow, we will be marketing these downpipes as “High Volume”
  • (Soon to be) EPA Approved (currently undergoing testing)
  • Top-grade materials, such as a brand new catalyst coating engineered specifically for Direct Injection applications
What does this mean for PRL’s other downpipe assemblies?
  • We will be implementing GESi/G-Sport’s catalytic converters in to these assemblies in upcoming months as well. Current supply chain issues, manufacturing lead-times and EPA testing have caused some delays, but no need to worry!
  • In case any 2.0L Turbo customers are reading this, we’ll have some more exciting news for you shortly!
Pricing will be announced shortly. However, customers can expect a notable price change from our current/previous downpipes due to the added costs of a larger, EPA-friendly, 400 CPSI catalytic converter.
11th Gen Honda Civic PRL Motorsports 11th Gen Civic 1.5T Front Pipe Development 241443812_997443300838043_9025803827572997223_n
11th Gen Honda Civic PRL Motorsports 11th Gen Civic 1.5T Front Pipe Development 241260473_1424362501273557_2779008935253159938_n
11th Gen Honda Civic PRL Motorsports 11th Gen Civic 1.5T Front Pipe Development 241490115_1239957703084775_4059458980700968089_n
The PRL Motorsports High Volume Downpipe Upgrade promotes optimal airflow with virtually no turbulence throughout the body of the downpipe. Like our standard downpipes, this will fit all factory heat shields, bracketry, components and front pipe. Our design utilizes 304 stainless steel investment cast ends, CNC pocketed for a smooth transition. All components are fully back-purged on site to withstand high exhaust gas temperatures. The wide shape of the cast inlet smoothly blends the turbine outlet and wastegate gases to reduce restriction, while the cast outlet allows smooth taper. All kits will include premium gaskets, stainless hardware, and components needed for a seamless installation.
PRL Motorsports
PRL Motorsports
Export, PA
prlmotorsports.com
Speaking of front pipes, we are excited to release our full 3.00” front pipe upgrade!
11th Gen Honda Civic PRL Motorsports 11th Gen Civic 1.5T Front Pipe Development Frontpipe-1
11th Gen Honda Civic PRL Motorsports 11th Gen Civic 1.5T Front Pipe Development Frontpipe-2
11th Gen Honda Civic PRL Motorsports 11th Gen Civic 1.5T Front Pipe Development Frontpipe-3
11th Gen Honda Civic PRL Motorsports 11th Gen Civic 1.5T Front Pipe Development Frontpipe-4
11th Gen Honda Civic PRL Motorsports 11th Gen Civic 1.5T Front Pipe Development Frontpipe-5
11th Gen Honda Civic PRL Motorsports 11th Gen Civic 1.5T Front Pipe Development Frontpipe-6
$399.99
11/11/2021 Expected Ship Date
Fitment Notes:
  • No tune required
  • Compatible with factory and/or most aftermarket downpipes – no adapter(s) necessary
The PRL Motorsports front pipe upgrade promotes optimal mid-range & top end exhaust flow and is recommended for customers who have already purchased a downpipe upgrade and are looking to push his or her 2022+ 1.5L Turbo Honda Civic even further. Our design utilizes 16 gauge mandrel bent 3″ tubing, CNC machined flanges and high quality, reinforced flex-section. All components are 304 stainless steel and fully back-purged on site to withstand high exhaust gas temperatures. Pair this with our 3″ Downpipe Upgrade for maximum exhaust flow and performance! All kits will include premium gaskets, stainless hardware, and components needed for a seamless installation.
11th Gen Honda Civic PRL Motorsports 11th Gen Civic 1.5T Front Pipe Development 241389064_2767804886802398_5190109259818660169_n
11th Gen Honda Civic PRL Motorsports 11th Gen Civic 1.5T Front Pipe Development 241543354_4354182998007143_5873833130989216057_n
11th Gen Honda Civic PRL Motorsports 11th Gen Civic 1.5T Front Pipe Development 242030881_290272332508686_2731548539172465481_n
Check out these sweet, CNC-machined, precision fitment jigs!
11th Gen Honda Civic PRL Motorsports 11th Gen Civic 1.5T Front Pipe Development 241177322_1486139931764071_8732846483202062563_n
11th Gen Honda Civic PRL Motorsports 11th Gen Civic 1.5T Front Pipe Development 242262351_591541991857848_7341521166359056983_n
11th Gen Honda Civic PRL Motorsports 11th Gen Civic 1.5T Front Pipe Development 241520636_1547540052253209_6335609521125906004_n
86salmon
It's Hedley, Hedley Lamarr!
SC
2018 Civic si sedan, 2001 Nissan Frontier
Any dyno plots yet? You know we need to see those sweet sweet gains
TypeSiR
Car Driver
On a Twisty Road
1.5T Civic, CTR, MX-5, Fit
So these will pass smog?
Pending EPA approval (downpipe) and it's got a bigger cat so it'll probably be fine. Can't even sell to the largest economy in the US or 5th largest in the world if emissions-related bolt-ons aren't certified.
PRL Motorsports
PRL Motorsports
Export, PA
prlmotorsports.com
Last week, we strapped our 11th gen to the dyno to test our new front pipe. We started with completely stock baseline runs at an average temperature of 59°F and an elevation of 1160ft, and both runs were performed on the same day.
11th Gen Honda Civic PRL Motorsports 11th Gen Civic 1.5T Front Pipe Development PRL vs Stock FP.PNG
With the car completely stock, we saw a maximum horsepower of 171WHP. After just a front pipe swap, we saw a maximum horsepower of 175WHP, and as much as a 7WHP midrange increase on completely stock ECU mapping.
