How did you find replacement blades? Went to autozone and they had no part info for our vehicle. Took the old blades off to measure them but the new blades didn't fit even with the adapter. Had to return/refund and put the crappy stock ones back on.I swapped out my wipers due to the factory ones lifting in cold weather, this maintenance setting is a must to prevent damage. I never would have known about it if I had not read about it in a post, the dealer really needs to show you this when you pick up your car.
You have to buy OE versions of any blades you get, and then modify the one clip that comes with them slightly, just clipping off two plastic "ears" so the blade slides deeper into the wiper arm. There are no aftermarket wipers listed for our cars yet, but I am able to modify the clips that come with OE style wipers - our cars use a 19 inch and 24 inch wiper.How did you find replacement blades? Went to autozone and they had no part info for our vehicle. Took the old blades off to measure them but the new blades didn't fit even with the adapter. Had to return/refund and put the crappy stock ones back on.
