procivic
- Joined
- Jan 29, 2016
- Threads
- 71
- Messages
- 688
- Reaction score
- 144
- Location
- Ventura, California
- Website
- www.procivic.com
- Vehicle(s)
- 2022 Civic Si Sedan, Others
- Thread starter
- #1
If you go on spirited drives or track your 10th Gen 1.5T Civic, you seriously might want to consider this new product we just got in stock:
SiriMoto Engine Oil Cooler Kit: https://www.procivic.com/…/sirimoto-engine-oil-cooler-kit.h…
It addresses probably the biggest shortcoming of the 1.5T motor (including the Si), which is that engine oil temps can skyrocket because of the high output of this motor and the fact that the engine oil is circulated through the very hot turbocharger unit. The factory oil system does not have anything in place to keep the engine oil cool.
This applies even more if you've modified your 10th Gen to produce more power or it is hot outside. The bottom line is the ECU will reduce ignition timing and lower boost levels as needed to save your engine and turbocharger from failing when oil temps get too high. This obviously causes a large drop in power. If you track your Civic or drive it aggressively for awhile, you might have already noticed this occurring. We found this out early on in our track testing of our first 10th Gen EXT Civic and knew there needed to be a solution.
Luckily for us and anyone else who likes to drive their Civic aggressively, there is now a complete solution that will keep your 1.5L turbo engine oil (and engine) from overheating. The great part is that this SiriMoto Oil Cooler Kit is 100% bolt-on, and comes with everything you need for the installation, even hex keys and an aluminum AN wrench! The kit was very carefully designed over the past year to exacting tolerances, and no expense was spared on the quality of the components.
Here are some quick specs on the 10th Gen 1.5T kit, but follow the product link at the top of the post for even more details.
(Honda oil filter not included)
Looking to do the install on your own or just curious about how it fits? Check out our full install video:
- Pre-Assembled -10AN hoses (Qty. 2).
- -10AN ORB to Male Port Adapter Fittings (Qty. 3).
- 90-degree -10AN Female Union (Qty. 1).
- All aluminum 19-Row Oil Cooler Core with Mounting Brackets. Coated in a silver finish for corrosion resistance.
- Core Size: 285mm x 150mm (11.2" x 5.9").
- Core Thickness: 50mm (1.96").
- Sirimoto Oil Filter Take-Off.
- SiriMoto Oil Filter Pedestal and Bracket.
- SiriMoto Black Fender Washers with Rubber Nuts.
- Silver Zinc Coated Flanged Hex Head Hardware.
- -10AN Aluminum Wrench and 3mm Ball-End Hex Key.
- Blue Thread Locker.
- Fluid Capacity Increase: ~1 Qt.
- Optional Oil Filter: PLM Style (PCX filter not recommended due to space constraints).
