Viet_Racer
- Thread starter
- #1
Translated via Google Translate
"This is a report on the test of the newly updated FL5 Civic Type R at Sodegaura Forest Raceway.
This time, we will conduct a set-up test that also serves as a matching of the full-spec damper and rear wing.
Based on the impression of the driver, finely adjust the spring and damping. While collecting various data such as vehicle height adjustment and rate change, exchange is completed in a short time until the next run.
Furthermore, we will continue to explore the best set while discussing things such as "Is there a little more pitching?" During one session, I adjust the bump/rebump attenuation many times.
The rear wing is too tenacious in high-speed corners, so I laid the rear wing down one step. As a result, the turning performance is improved. We will set it according to the characteristics of the car.
After that, we continued to test various settings and searched for specifications that we were satisfied with. In addition, we will decide on specifications that do not impair the ride quality, including everyday use.
We will do our best to commercialize it as soon as possible, so please wait a little longer.”
