Warning about 25 Urban Gray Pearl
Stanleywinthrop
Usa
10th gen
I recently ordered OEM touch up paint for my car. The paint code on my window jam is N912P. The paint stick I received was labeled Urban Gray and the code on the bottle was N912PAH-A1. I figured this was fine. Much to my surprise, after application, the dried paint was noticably darker than the factory paint (my car is only 6 months old so it hasn't had a chance to fade significantly.) This remained true even with a layer of clear coat.
The only conclusion I can draw is that Urban Gray is different from Urban Gray Pearl. If you get a touch up stick with the second code above don't use it!
I found some aftermarket touch up paint with the correct code and it is a much closer match.
Baby blue
Cary
Illinois
2023 Honda Civic Type R, 2022 Honda Accord 2.0T Touring
You mean door jam? Right? The sticker in the door jam?
It's very difficult to get pearl effect without a separate top coat.
I recommend consulting an automotive paint store for advice. These stores custom mix spray cans or touch-up paints for good results per my experience.
