What features do you want?
THATSi
Nick
Orlando FL
17 Civic Si
Personally there's a few features I'd like to see Hondata add and figured why not see what everyone else would like to see their next feature be.
I really wish there was a way to disable VSC without losing the ADS and keeping the suspension tighter. Also the fact that I can't use the brake hold feature without my seatbelt on really annoys me.
Triple_peaz
Brother Taresa
Brandon
Louisiana
2019 Honda civic si sedan, 2016 Honda pilot
I don't know if this was a problem for other people, but when I had my 8th Gen and I used a base tune it disabled my oil life percentage. It would always be 100%.
I don't know if it's like that still. I have a 2019 si and will be ordering a flashpro today.
MT_FK7
WOP Hatch
Would be nice to not have to have your foot on the brake to turn off the parking brake...
My FP is currently uninstalled because I’m trying to get into the dealer for oil dilution reflash, so a fix for the updates binaries would be nice too...
THATSi
THATSi
Nick
Orlando FL
17 Civic Si
Bring this thread back to life. What's been mentioned here so far is good, but the list is short, specifically the release parking brake with no pedal, for burnouts this is awesome, but needs more, I've noticed that by default the launch control locks in if wheel speed is under 3mph, creates a problem cuz by rear wheel speed sensors it doesn't let go during a burnout. So that's one, gonna go further, and this is, imo, the biggest problem between ktuner and hondata, the VTC table ends at 6900, while hondata allows you to set your redline higher, it's a moot point cuz at 6900 it resets to 0 degrees, and actually you could risk engine damage, my other big complaint and here it is, money in it for them to as an add on, the bluetooth won't run the hondata app without being plugged in. My problem with that is the long wire to the ODB plug in, I can lay it in the cubby under the dash but that wire is always hitting my legs as I drive and is annoying as shit and I don't want it strapped up out of the way cuz I don't want to run it all the time, what about a plug in bluetooth piece that stayed on the ODB and if ya need to upload plug into that, no wire until you needed it, and as far as I know, no one doing that
bikejog
ny
2020 Civic SI Coupe. 2000 Honda Prelude (donated to charity).
Yeah the no brake pedal e-brake release would be very useful. I couldn't release the e-brake with the engine off. That could be a big problem if your car won't start and you need to release the e-brake.
turbociv910
taylor
wilmington nc
19 SI, 99 ex b20v
You can release the parking brake with the Engine Off.
bikejog
ny
How? I tried but it wouldn't release. With the engine off, I pressed on the brake pedal but it wouldn't go down all the way and I press down on the e-brake button but the brake wouldn't release. I think I tried a few separate times.
turbociv910
taylor
wilmington nc
19 SI, 99 ex b20v
Accessory power has to be on
THATSi
THATSi
Nick
Orlando FL
17 Civic Si
Back to his original point tho, if the battery is completely dead you're stuck, and a tuning solution probably wouldn't fix this with no power to the ECU
turbociv910
taylor
wilmington nc
19 SI, 99 ex b20v
Car not starting doesent mean dead battery. But I see.
THATSi
THATSi
Nick
Orlando FL
17 Civic Si
Right but even if no crank no start condition you still have power to put it in accessory mode and take the e brake off
bikejog
ny
Pretty sure I tried Acc as well as Run Power. But I'll try again some other time.
Maybe I was expecting it to work like the manual e-brake thus didn't turn Acc on? Lol... I'll report back after I try it.
bikejog
ny
I'm ok with not be able to release e-brake when battery is dead. duh.. lol..
turbociv910
taylor
wilmington nc
19 SI, 99 ex b20v
which is a problem to press a button? Theft deterrent.
bikejog
ny
Yes I confirm that the engine doesn't have to running to release the e-brake. Acc power on, step on brake pedal, and press down on e-brake button.
