WHEEL W/ BBK SETUP QUESTIONS
CaliBlueSi
Geovany
2022 Honda Civic Si
Hi everyone,
I'm on the search for my first aftermarket Wheels for 22 Civic Si. I am planning on installing 27WON BBK but want to run it without Spacers.
I was hoping to get suggestions for wheel/wheel specs that would do so. FYI my dream wheels would be the DESMOND REGAMASTER EVO but not sure if they make the specs for my car.
Thanks!
madbikes
SF Bay Area
If this is your first time, the easiest way is to ask 27WON which specific wheel clears. It may not be the wheel you want, but it is the worry-free option. They should be able what wheel spec they'd recommend, or provide a template for you to be certain if the wheel you bought will clear the caliper.
You can also see which wheel people who run that BBK use. In case Desmond doesn't offer wheels for 22' Si, you have other option(s) to consider.
