When to connect Ktuner V2 for Datalogging right Map
Myx
Delaware
2018 Honda Civic EX (Hatchback/CVT)
Car: 2018 Honda Civic EX CVT
Ktuner: V2
I have 3 maps uploaded. 1: Ktuner Basemap, 2: Custom Map on 93 Octane, 3: Custom Map on Boostane
Problem: When at the track, I'd hook up my V2 to datalog. When I set my map to 3, (Boostane Map) and datalogged, I was running slower 1/4 mile times. When got home and looked at the datalogs, I notice my ignition advance, turbo psi, etc wasn't on the Boostane map but what looked like the base map. It seems I have to start the car up, set the map I want to use and hook the Ktuner V2 up in a specific order or else, hooking up the V2 will switch the maps around.
Is there a correct/proper way to do this so that I am datalogging the map I set it at, rather than it get switched around somehow?
Is it: Start car, set map, connect V2 to datalog?
Or Hook V2 up, start car, set map
Or Start car up, hook V2 up then set map?
Or Something else
Thanks in advance!
gtman
Mitch
2017 Cosmic Blue EX-L Sedan
When I datalog, I plug the V2 in first. Start the car next. And set the Map I want last.
What I think happened to you was this...
You started the car, switched to Map 3 and THEN plugged the V2 in. And here's what happened:
The V2 will revert to the last used tune when you plug it in. The last time you had the V2 hooked up you must have been on Map 1. So even though you had manually set it Map 3, plugging the V2 in changed maps.
Viola! The case of the mixed up maps solved. :cool:
  • Like
Reactions: Myx
Myx
Myx
Delaware
This is EXACTLY what happened. I still was going to be doing this because it seemed like it was the right order. I'd start the car, set what map number I wanted, then connect the Ktuner V2.
If I get time, I'll do this today and see if it stays on the map I wanted it on by doing it the way you described. Big thanks!
Myx
Myx
Delaware
The unit will switch the map when it's powered if it does not currently match.
You can also just choose the map from the V2 once it's powered. OTF is an option on the main menu.
I didn't know I could do this. Thanks!
