Which EDC canceller known to work for FL5 (for coilover install)
azev
Oregon
CW FL5 CTR
I am having trouble finding EDC canceller that works for FL5.
I tried 2 brand, one is nitron, and some ebay one from china.
Unfortunately both of them seem to not work as expected since changing drive mode with the edc installed often throws edc failure error.
The one I got from ebay seems to work if you don't fiddle with drive mode, but if you keep changing the drive mode while driving it will throw an error. Especially if you put it in R mode, the error would come up almost instantly as the mode change. I am not sure if this is the expected behavior, nor have I tested a long drive without changing the drive mode to see if the error would be triggered.
Anyway the code would disappear if you turn of the car and start it back up.
For those of you who have coilover installed (non RSR)on your FL5 what EDC canceller do you use ?? does it comes pre installed with the correct plugs for plug and play ?
Does it throw errors when you played around with the drive mode ??
I thought the edc canceller was supposed to emulate the shocks absorbers, so in theory, changing drive mode should not trigger any code rite ?
Just curious if anyone in forums have a known working edc canceller for FL5 and what the expected behavior when you have edc canceller installed.
Thanks
Tougefl5
Banned
Banned
I really only deal with KW for any suspension components.
I just recently had module failure. Most likely due to install. called KW and explained what happened.
They sent me a brand new module a few days later.
Didn't give me a hard time about it. Email me the tracking number and gave all the information from the first and only phone call.
BigBird
correct. the canceller should not trigger any codes when swapping modes.
