2 sets of wheels
jchall30
Winchester, KY
Maybe a rookie question here but how do you have 2 sets of wheels and tires registered to the FL5? I wanna have a winter and summer set and switch back and forth. Does the FL5 allow this and if so how does it work? Thanks guys!
daazn
97 Miata
You just buy another set and swap them out when you want
yeaitsahonda
David
Virginia
2023 Boost Blue Type R
Somebody can correct me if I am wrong but I don't think our cars have tire pressure sensors. It uses wheel speed to determine if a tire is getting low. So you shouldn't have to worry about programming new sensors to the car. When you swap wheels (or rotate your tires) you just go into the settings menu on the main screen and select calibrate TPMS. The car will take it from there.
jchall30
jchall30
Winchester, KY
I had read that but wanted to make sure. If that’s the case that is super easy. Thank you
