Anyone try the 11th gen SPOON springs yet? Or H&R?
DPL8
Boston
2017 Honda Civic Type R 3388
I'm running them. It greatly improves the ride quality over stock. And I personally like the drop. It looks like more than 0.7" but I measured and did in fact only drop 0.7".
Awesome! That’s exactly what I am looking for, did you have to get camber arms? Or was it fine without?
Mobias
2024 Civic Type R, 2006 S2000
I did camber arms anyway. So unfortunately I can't tell you if they were necessary.
kart17
MI
2025 Civic Sport Touring Hatch
Piggybacking on this thread since spring rates were mentioned does anyone have the rates for the FL4 Hybrid? I'm assuming the rates will be similar to the FL1 hatch maybe a bit stiffer to account for the battery but not by much. Thinking of doing an SI damper & spring swap in the rear and then possibly RSB. Not looking for a drop coming from an MK7 that had Koni SA's. The FL4 needs a bit more body control.
chibisky
Civic FL4
I'm unsure on the FL4 stock spring rates, but I do know Spoon lists separate springs for FL1 turbo and FL4 hybrid but both list the same spring rates.
https://www.blackhawkjapan.com/products/spoon-51400-fl1-001?_pos=2&_sid=62e51777d&_ss=r
https://www.blackhawkjapan.com/products/spoon-51400-fl4-001?_pos=1&_sid=b48b4ae67&_ss=r
The one for the manual FL1 RS seems to list different spring rates though.
https://www.blackhawkjapan.com/products/spoon-51400-flrs-001?_pos=1&_sid=62e51777d&_ss=r
