D2 Racing Lowering Springs
procivic
Ventura, California
www.procivic.com
2022 Civic Si Sedan, Others
We have D2 Racing Pro Lowering Springs available for all non-Si and non-Type R 2016+ Civics now!
These springs are high quality (ISO 9001 and TUV approved) and will lower your 10th Gen Civic by about 2" front and rear, depending on your exact model. This is probably the least expensive way to get rid of the factory wheel gap that takes away from the overall sporty look of the car.
See our site for details on your application and to purchase: https://www.procivic.com/p/m/civic/d2...g-springs.html
11th Gen Honda Civic D2 Racing Lowering Springs 42170_1165___D2%20Springs%202016%20Civic
Shankmeyster
AZ
23 Type R
Gonna be a group buy at some point on the coilovers?
procivic
procivic
Ventura, California
www.procivic.com
How close is the spring rates to the Si?
I'm not sure of the Si's exact springs rates. Generally these D2 springs will be slightly stiffer than the factory ones.
AsianGuy98
Illinois
2017 Civic Si Sedan
Have you heard of any companies that are developing Si specific lowering springs?
AsianGuy98
Illinois
2017 Civic Si Sedan
So is it safe to say that Si owners can use the Sedan springs if they have a sedan?
procivic
procivic
Ventura, California
www.procivic.com
We haven't test fitted the non-Si springs on the Si. They could work, but we're just not 100% sure yet. I think the chances are high they would work without any issue, but before we advertise they do, we need to know for sure.
Jessi
Jessi
Fresno, CA
2017 Civic Sport Hatchback
Is a camber kit neccesary? Or is it ok to just switch the springs and get it aligned? (Specifically on the hatchback)
procivic
procivic
Ventura, California
www.procivic.com
A camber kit is recommended, but if you don't get one, it just means your tire wear might be a bit off. Before purchasing a camber kit though, I would actually get the alignment tested (after the springs are on) to see how off it is.
