FK8 Spare Tire Kit installed in FL5
modernDAYmods
Merv
2023 Honda Civic Sport Hatchback, 2002 Subaru WRX
I daily drive my FL5 even though I have a bugeye Subaru. One thing I did not know about the FL5 is that it didn't have a spare tire. Thanks to original poster hhkb for his post, I was able to get my hands on the OEM Kit and Spare tire at my local dealership in SoCal. If you want to see the original post, please go here. https://www.civicxi.com/forum/threads/exploring-a-clean-fk8-spare-tire-kit-install-in-the-fl5.53627/
If you are wondering if the OEM FK8 Spare Tire works in the FL5. It does, with modifications and finessing the trunk floor mat.
Note: this installation is opposite to what some users have done in removing the 4 squares of foam. I will be "adding" foam and supporting stress areas in this install. I put several groceries in my trunk and would really like a planted flat surface.
Things you'll need to do:
Order the following parts from your local dealership. This will cost around $380 or less depending on your dealership. You do not want to have this shipped to your house. Save yourself the cost and pick it up. Note: The OEM box for these items is VEERRRRY bulky but will fit in your FL5 with seats down.
06421-TGH-A33ZA - FK8 Spare tire kit, includes the rim, FK8 floor board, scissor jack, scissor tools, FK8 tow hook, spare tire psi stickers and stickers for driver door jam as well
42751-CTL-039 - This is the continental tire
The dealership can install the tire to your spare for $30 or you can take it to any cheap tire shop and they do install only for $12, in my experience. (balancing is not necessary because you aren't supposed to drive beyond 40 mph with this spare anyways)
Amazon order:
-Quantity of 2 9"x6"x3" Yoga blocks
-Quantity of 1 2" Inch Thick Foam Yoga block to cut to pieces
-Goop trim glue
Various items and tools needed:
-Masking tape from harbor freight or anything similar
-Pair of scissors, screw driver, wire cutters & serrated knife
Step 1 - Remove your FL5 Tray cover and replace it with the new FK8 tray cover. Two screws under a cover at the holes
Step 2 - Remove your privacy retracting screen from the trunk
Step 3 - Cut your 2" yoga block using your serrated knife. You want to cut enough to add to the green areas in the first picture. It should boost each block to at least 5" in total. I wouldn't worry too much about how it looks, it will all be covered in the end. Add 2 strips of masking tape to test fit all the pieces. Adjust as needed.
>>Green indicates the need to add material to boost to 5"
>>Red indicates the need to create your own stack/block to support the added gap
>>Blue indicates an area where you can wedge the large Yoga blocks without modification
Step 4 - This is an optional but recommended step, create your own stack of blocks or a solid block to fill in the red squared areas. These are stress points that are empty and would benefit with support, otherwise you will feel like the board has gaps that can cave in.
Step 5 - Cut down the left flap board with wire cutters, use the adhesive side of masking or tape to pick up the dirt and debris
Step 6 - After test fitting the board and you are satisfied, remove and add 'Goop' to each addition. I used the same masking tape to hold it in place along with closing the board down so that it all stays in place. Give it time to dry.
Step 7 - Modifying the trunk mat requires your hands and scissors. You can use a heat gun if you would like, but I skipped on this and cut some corners, literally.
>>Red squares indicate areas where you'll want to invert with your hands
>>Teal indicate where you want to invert the orientation of the mat by reverse folding the mat with pressure
>>Red lines indicate where I cut off material or made cuts.
The result is a nice flat surface right from the trunk lock with the same benefit of the trunk tray mat. If you prefer to run it without the mat, it looks even better. My car is a daily, so I do not mind how this looks and would prefer coverage from dust and accidental spills.
11th Gen Honda Civic FK8 Spare Tire Kit installed in FL5 2025-06-21 14_03_52
11th Gen Honda Civic FK8 Spare Tire Kit installed in FL5 2025-06-21 14_08_23
11th Gen Honda Civic FK8 Spare Tire Kit installed in FL5 IMG_2498 - Copy
11th Gen Honda Civic FK8 Spare Tire Kit installed in FL5 IMG_2495 - Copy.JPG
11th Gen Honda Civic FK8 Spare Tire Kit installed in FL5 IMG_2493 - Copy
11th Gen Honda Civic FK8 Spare Tire Kit installed in FL5 IMG_2492 - Copy
11th Gen Honda Civic FK8 Spare Tire Kit installed in FL5 IMG_2484 - Copy.JPG
11th Gen Honda Civic FK8 Spare Tire Kit installed in FL5 IMG_2472
11th Gen Honda Civic FK8 Spare Tire Kit installed in FL5 IMG_2444 - Copy.JPG
Blindeye_03
Cincinnati Ohio
'24 CTR - red
I removed those 4 smaller square blocks and mine fit 'flat'. Now I didnt use the center styrofoam piece because I have my tools secured a different way.
modernDAYmods
modernDAYmods
Merv
Yeah, there are a couple ways you can work this install, however, I noticed weak/stress points with this trunk cover that I was not a fan of if I were to put heavy items in the back. The FL5's in Brazil have a foam insert that supports the board at all points, comparing it to the FK8 board, it's super weak and flimsy. I wanted a solid platform for when i put wheels/tires in here and groceries.
I am also setting it up to retain the wheel foam insert once I get my hands on a sport touring trunk insert. OR I might just modify the FL5 foam insert to hold the scissor jack, but for now I am content.
11th Gen Honda Civic FK8 Spare Tire Kit installed in FL5 Compress_20231017_214358_8455
Navy619
Jonni
San diego
FL5, rav4, S13, XL40
This is our only inexpensive option for the spare tire swap. I bought the fk8 spare kit and paid 350 otd with the tire at my local honda. I would advise calling around these dealers will tax you.
11th Gen Honda Civic FK8 Spare Tire Kit installed in FL5 20250619_125431
11th Gen Honda Civic FK8 Spare Tire Kit installed in FL5 20250619_124521
11th Gen Honda Civic FK8 Spare Tire Kit installed in FL5 20250619_125628
modernDAYmods
modernDAYmods
Merv
Yeah, definitely get quotes before you buy the kit. You don't want to be spending more than $370 with tax for the FK8 kit and tire.
Sad we can't get a proper kit for the FL5, but this will do...
timestamped
DC
Right after I picked up the car last year, I got a wheel and tire off eBay for $300, a Jack kit (I think from a Chevy Equinox, $30) that sits flush within the depth of the wheel, some conical lug nuts, and added some tools and containers around the sides of the spare. Later I got the red JDM carpet to cover all of it. It’s a comparable other option that lays flat and is supportive.
11th Gen Honda Civic FK8 Spare Tire Kit installed in FL5 IMG_0210
11th Gen Honda Civic FK8 Spare Tire Kit installed in FL5 IMG_8629
11th Gen Honda Civic FK8 Spare Tire Kit installed in FL5 IMG_8628
11th Gen Honda Civic FK8 Spare Tire Kit installed in FL5 IMG_0213
11th Gen Honda Civic FK8 Spare Tire Kit installed in FL5 IMG_9779
Ph8ed4life
AZ
2025 CW CTR
Nice work, thank you for taking the time to document and share!
I did the FK8 kit, removed the 4 center blocks, added to areas for more rigidity, and store the tools differently. Lastly, I picked up a UKDM carpeted mat to round it out.
Many ways to accomplish something that should have been OEM installed in the first place... although, I'd imagine people would then bitch to no end about the trunk space and the lack thereof.
