Wisconsin FS: Remark triple tip SS in Milwaukee / Chicagoland
True it’s all about how you drive it if I’m honest. If I’m driving aggressively I’m not in the 3K RPM range long enough for it to be an issue. It’s basically when I’m commuting in R+ (valve open) that it’s annoying. So maybe my problem is how I’m using the exhaust. If this drone doesn’t exist in other exhausts I would lean to go in that direction. But if it’s about the same in all of them, it think I can live with that. Didn’t think I would be an early adopter two years into production but seems this is the case
Based on what I see what’s available for our car with a valve, you’re likely better off with a Kakimoto. The layout seems exactly like stock. Even the seeker might be worth a try. It’s hard to try when all these exhausts are $2k+
Be advised, the Kakimoto system weighs more than stock. Might be something to consider if you're concerned at all with weight.
Two of the better sounding exhaust systems available IMHO.
powerofdreams
Illinois
2024 Honda Civic Type R
Not sure if you still have the exhaust on the car. But if you're ever down in Chicagoland, I'd be interested to hear it in person.
