GarageLine.com: Civic Si & Sport Wheel Spacers
hfpdohc
Hatch 2017 M/T
At stock height you should be ok. We run 20mm front and 25mm rear and haven't had any rubbing. 25's lowered i expect some rubbing with stock alignment specs.
ive heard that people rub now on stock height on big bumps......glad i didnt bought
givemeadollar
Multiverse
2018 Civic Si Coupe
I run eibach pro kit, thats why the rubbing. Stock ride height I had no issues with the 20mm front 25mm rear.
RLegionSi
Raul
Red 2018 Honda Civic Si
You guys wouldn’t happen to sell 25mm alone? I have a pair of 20mm for the front. Wanted a pair of 25mm for the rear. Running Eibach Pro Kit w Truhart Camber Kit
mofoD
D$
Houston, TX
Aegean Blue '18 Si Coupe (Toy), White Orchid Pearl '16 Accord Touring V6 Coupe (Daily)
i dont rub whatsoever on stock height.
probably best money spent was on these spacers.
miss out on em, modding isnt for you.
Deezy
Daniel
Covington, Ga
2018 Civic LX Sedan 6MT (FC2)
What's to keep these from fitting on a LX sedan?
Edit: Not sure why only spacers for the Si and Hatch are listed, as all trims have a 64.1mm hub. I purchased the ones for the Si, and they fit with no problems.
Steph_k7
@kanjodream
Stephen
Oak Harbor, WA
2017 civic hatchback
GarageLine.com: Wheel Spacer Packages (15mm, 20mm, 25mm)
20/25 Combo Installed:
More Images Here:
http://www.garageline.com/blog/new-product-2017-honda-civic-si-wheel-spacers/
MSRP: $220 for a set of 4
Intro Price: $195
https://garageline.com/honda/280-22...-spacer-combo.html#/29-spacers_size-20mm_pair
Our spacers are built to last, made from 6061 Aluminum and anodized black not only for the cool look but for corrosion resistance. All of our spacers are hubcentric so they have the proper hubsize and are guaranteed not cause a vibration at speed like other cheaper spacers. We use Grade 10 bolts like your stock wheel studs so they are strong as OEM equipment. They do no require extended studs or cutting your stock studs.
100% Bolt on!
[email protected]
240-516-8863
Do these spacers also fit the non sport hatchback models?
M1K3_V
Miami, Fl
2017 Honda Civicc Si; 2016 Harley Davidson 48
@GarageLine.com Will there be a black Friday or cyber Monday sale in November? I'm ready to buy now, but if I can save a few extra bucks, I can wait.
Cocain.civic
Rudy
Cali
2017 Civic si
Okay. I have a 2017 civic si and im Lowered on ebach. If i get 20's all around will i rub???
