Redline360
- Joined
- Sep 11, 2015
- Threads
- 153
- Messages
- 460
- Reaction score
- 18
- Location
- Bay Area
- Website
- www.redline360.com
- Vehicle(s)
- Civic
- Thread starter
- #1
Only $630 shipped! Please click here to order:
GodSpeed Coilovers Honda Civic Coupe/Sedan [MonoSS] (2016-2018) MSS0129
- Fits 2016, 2017, 2018 Honda Civic All Models
- 52mm Mono-Tube Stainless Steel Shock With 16 Levels of Damping Adjustment Corresponds to Daily Driving Scene To The Sunday Track
- Performance Internal Piston With Koyo Japan 6204z Bearing Provides Smooth Stroke; Powder Coated CNC Machined Aluminum And Carbon Steel Accessories
- Independent Spring Tension And Height Adjustment; Racing Grade Shock Oil With High Viscosity Index; Shock Absorber Can Be Rebuild When Worn Out
- Full 1 Year Limited Warranty From Date Of Purchase; Install By Experienced Professionals Is Highly Recommended
APPLICATIONS:
- 2016, 2017 Honda Civic (FC)
FEATURES:
- Front camber plates with pillow ball mount for camber adjustment
- Spring rates: Front: 6 kg/mm / Rear: 6 kg/mm
- 16 precise levels of damper adjustment
- Koyo Japan 6204z bearing
- Polyurethane bushing (if applicable)
- Monotube shock design
- Anodized shock body
- Lightweight aluminum lower mount and T7075 forged aluminum / carbon steel brackets
- 52mm carbon steel shock body with a performance internal piston
- Independent ride height and spring preload adjustments
- Race shock oil with a high viscosity index
- 1 Year Warranty from Date of Purchase
Rate(kg/mm) 6 6
Length (mm) 160 180
I.D. (mm) 62 62
Camber Plate Yes No
Prior to installation, verify all hardware and properly preload suspension to 10mm. Our technical department is available to answer any other questions.
