How can i use the launch control?
GixxerMKD
Baze
Macedonia
Honda Civic 1.5 Hatchback Sport 2018
Hi guys, i was playing today with the on the fly map changing option and actually went into the launch control settings because i was holding the clutch :) Anyway, i can adjust the rpm in it, but when i press cancel again im back to the normal dash settings, so the question is how do i actually use the launch control??
kytos
Marcos
Madrid - Spain
CIVIC SPORT 1.5t 2017 EUDM
Set your desired RPM, clutch in, 1st in, floor it and let the clutch.
GixxerMKD
GixxerMKD
Baze
Macedonia
Thank you :)
btw, what's the default for good start, isn't 4600 too much?
kytos
Marcos
Madrid - Spain
You may want to find yourself as it depends on the traction capability (wheels, temp, surface..) and engine power (tune, response) also how fast you let the clutch and the traction control setup. I found somewhere between 3000 and 4000 ideal for me, but i try to not abuse it as it's hard for the transmision and clutch.
