New Brake Upgrade Options from 27WON
Vlad@27WON
Vlad
Las Vegas
"22 Si, "23 Integra
Pretty excited to share a few new launches from our team for the FL5 & FK8 Type R as well as the Integra Type S.
https://store.27won.com/2017honda-c...ra-types-front-big-brake-kit-bbk-6piston.html
11th Gen Honda Civic New Brake Upgrade Options from 27WON 1787854747167-62
https://store.27won.com/civic-type-r-integra-type-s-fl5-de5-fk8-350mm-rear-rotor-upgrade.html 11th Gen Honda Civic New Brake Upgrade Options from 27WON 1787854717551-b0
Not too long ago, we introduced the first upgrade in our line of brake parts with the 27WON 6 Piston Front BBK. They had all the usual components like larger calipers, 2-piece 355mm rotors, stainless lines, etc. And one of the immediate pieces of feedback we got was along the lines of ā€˜hey, I already have 2-piece rotors and I want to keep them, but I want the larger calipersā€. So naturally, we set out to do something about that.
Re-engineering the caliper mounting bracket for the slightly smaller (350mm) OE rotor didn’t prove too difficult. Everything else drops in place including the same 6 piston caliper from our full BBK. Stainless lines, brake pads, and all the typical hardware is also included. Intro price on these kits is $1599.99. Available in Red or Black.
Ok, so that’s the front. For the rear we are rolling out a 350MM rotor upgrade. These feature color matched caliper brackets (in red) to allow customer to re-use the same caliper but now on a much larger rotor. 305mm (factory) -> 350mm (27WON). Rear rotors are 2-piece and slotted for better performance under hard use. Think track or spirited street drives. A black coating ensures these come delivered corrosion free. It’ll wear away after a few hard stops. Pricing is $899.99 for a set. You can use OEM pads on these or upgrade to a set of our performance pads we offer for the rears.
As always, here to answer any questions. You can pick these up directly from us or any of our domestic and international retailers.
