P2R Throttle Body Spacer | Available For 1.5L / 2.0L
kseriesparts
Colorado
Increase horsepower and torque with this 3/4 inch throttle body spacer. Our spacer comes equipped with a 1/8th inch NPT threaded port at the bottom that can be used as an extra vacuum port or nitrous. Includes extended bolts, plug, and is anodized for a brilliant show-quality look.
https://www.kseriesparts.com/merchant.mvc?Store_Code=CR&Screen=PROD&Product_Code=P2R-P343-SLV
Power Rev Racing Throttle Body Spacer: Silver 1.5L Turbo
https://www.kseriesparts.com/merchant.mvc?Store_Code=CR&Screen=PROD&Product_Code=P2R-P343-RED
Power Rev Racing Throttle Body Spacer: Red 1.5L Turbo
https://www.kseriesparts.com/merchant.mvc?Store_Code=CR&Screen=PROD&Product_Code=P2R-P342-SLV
Power Rev Racing Throttle Body Spacer: Silver 2.0L
https://www.kseriesparts.com/merchant.mvc?Store_Code=CR&Screen=PROD&Product_Code=P2R-P342-RED
Power Rev Racing Throttle Body Spacer: Red 2.0L
11th Gen Honda Civic P2R Throttle Body Spacer | Available For 1.5L / 2.0L P342
k20martinez
Peoria Arizona
2016 Honda Civic EX
Bought this product for my 2016 Civic ex and it was sent to big told me they were going to get this fixed it's been 4 weeks and nothing yet
kseriesparts
kseriesparts
Colorado
Can you give us a little more detail? What was tot big? Who told your they were going to fix it?
k20martinez
Peoria Arizona
2016 Honda Civic EX
P2r had told me they will fix the problem, I have been emailing them. The spacer was built to thick and caused rubing inside the engine bay and they have to make them all thinner now. I added pictures
11th Gen Honda Civic P2R Throttle Body Spacer | Available For 1.5L / 2.0L IMG_4770
11th Gen Honda Civic P2R Throttle Body Spacer | Available For 1.5L / 2.0L IMG_4771
11th Gen Honda Civic P2R Throttle Body Spacer | Available For 1.5L / 2.0L IMG_4773
k20martinez
Peoria Arizona
2016 Honda Civic EX
We just contacted P2R and they told us the new spacers are already milled for better fitment. They just need to get anodized and they will be sending you a new one out.
Been over 40 days since this and I still haven't received any product I have a shipping label sent ans email no replys or update it's ridiculous
kseriesparts
kseriesparts
Colorado
According to P2R they got them back from anodizing on Friday. So you should see your new on very shortly.
saiyan1485
2016 Honda Civic LX Sedan Manual
So i received my throttle body spacer and my engine made a knocking sound when i start the car. also all the pedals were shaking.. When i took the car for a drive it felt like the car wanted to shut off...Any idea why then would happen?
360glitch
Moderator
I'm not sure exactly what it takes to install one of these but you need to make sure that everything is sealed up, no leaks on the intake side. Make sure all sensors are securely plugged in and that you did not get anything dirty that you shouldn't have.
saiyan1485
Everything was in order. I dummy checked and triple checked. All the weird stuff happened after but when i took it out the odd stuff stopped. My car is back to normal just when i put the part in is where it happen. By the way the spacer is 5/8 thick and the gasket is 3mm or 4mm.
360glitch
Moderator
While I admit I would not expect any gains from a part like this it should not hurt anything if properly designed and installed. Either way, it may be best to leave it out of your engine bay.
