PERRIN Shifter Cable Lock
PERRIN
Hillsboro, Oregon
www.perrin.com
2017 Civic Type R
Improve the feel of your shifter and remove rattle with the PERRIN Shifter Cable Lock.
PERRIN.com
10th Generation Civic shift cables are not well secured in the shifter cable housing. This causes a noticeable "double-clunk" while shifting into 2nd, 4th, and 6th gear. This problem is exaggerated when aftermarket short shifts and adapters are installed.
Locking The Cable Down
The PERRIN Shifter Cable Lock compresses the shifter cable housing around the shifter cable mount, locking it in place and eliminating any movement.
11th Gen Honda Civic PERRIN Shifter Cable Lock PHP-INR-018_07
Dampen Vibrations
The Shifter Cable Locks extended shaft uses tension bands to hold pressure on the cable eliminating any additional vibration between the shifter cable and the shifter cable sleeve.
11th Gen Honda Civic PERRIN Shifter Cable Lock PHP-INR-018_05
Finish & Construction
The PERRIN Shifter Cable Lock is CNC machined from lightweight aluminum for a precise fit. Anodized black and laser etched with the PERRIN logo and part number. While you won't see it again once it is installed, know that it will still be looking and working great for many years and miles to come.
11th Gen Honda Civic PERRIN Shifter Cable Lock PHP-INR-018_02
Please email [email protected] for your CivicX Discount
learn more at PERRIN.Com
