PERRIN Wheel Spacers
PERRIN
Hillsboro, Oregon
www.perrin.com
2017 Civic Type R
PERRIN Wheel Spacers move your wheels and tires outwards so they are more flush with the fender--instantly give your vehicle the perfect stance!
27mm Wheel Spacers & 20mm Wheel Spacers
11th Gen Honda Civic PERRIN Wheel Spacers PHP-WHL-027_01
PERRIN Wheel Spacers feature a ‘perfect fit’ hub-centric design that makes the spacer function as a precise extension of the axle hub, thereby guaranteeing precision wheel fitment.
11th Gen Honda Civic PERRIN Wheel Spacers psp-whl-020_07
Machined from 6061 Aluminum, PERRIN wheel spacers are hard anodized for superior surface durability and corrosion resistance.
11th Gen Honda Civic PERRIN Wheel Spacers PHP-WHL-027_08
PERRIN wheel spacers are perfectly sized to be an “off the shelf” solution for pushing stock Subaru wheels out flush with the fenders. Which spacers are right for you? Read our blog post to learn how to measure for spacers and see them get installed. PERRIN Wheel Spacer Blog Post
11th Gen Honda Civic PERRIN Wheel Spacers how_to_measurex800
On the 2017-2019 Civic Type R, PERRIN 27mm spacers front and rear are perfect for OEM wheels and tires.
11th Gen Honda Civic PERRIN Wheel Spacers php-whl-027bk_install_comparison03
11th Gen Honda Civic PERRIN Wheel Spacers php-whl-027bk_install_comparison02
The 20mm spacers fit the 2017-2019 Civic Si with OEM wheels.
frtorres87
Frank
New Jersey
2017 Honda Civic Type R
I’ve emailed but I haven’t heard anything back.
Caestus
Jeremiah
Miami Florida
19 Civic Type R
even with less aggressive ones?
I think so yes.... remember how everyone says my car looks lower at meets? I believe if I push the wheels out even a little bit I will get wheel rub. I'll post a picture later of how this looks.
Between my spare tire and baseball gear, there's at least 200lbs back there.
laz's SI
Lazaro
Miami, Fl
2019 Civi SI 4 door/ 2017 F-150
Any pics of the Si sedan before and after ?
