PRL expansion coolant tank sight glass not working
ra621h
Nagato
JPN
fl5
I bought the PRL coolant expansion tank and the sight glass isn't showing anything, it just has condensation on it. I filled it up checking the glass every so often and ended up over filling it because it showed nothing. Did I fill it wrong? Does any one here have some helpful tips or a good video I can learn from? I would hate to burn a perfectly good fl5.
BiggusRiggus
Joe
I had the same issue with mine. Sent it in under warranty and they sent me a new one. The sight glass still doesnt work properly. I feel like that sight glass should be fuller.
11th Gen Honda Civic PRL expansion coolant tank sight glass not working 20241124_104619
I did run the one that doesn't work for a while and the temps were fine, but the sight glass doesnt work.
ra621h
Nagato
JPN
fl5
我也是。
Still the same issue.the sight class doesn't work so far.what about yours now?
BiggusRiggus
Joe
我也是。
I contacted support and they agreed to refund me if I drilled a hole in the expansion tank. Never got either of the 2 tanks working properly. I have the stock tank now.
ra621h
Nagato
JPN
fl5
I try to loosen the nut of the sight class.
This is grand. I thought I was going to get this to replace my Radium tank since the sight tube isn’t accurate either. ?
