Radar and Dashcam install FL5 wiring assistance
Evasive
PSL Florida
2025 BB FL5
I have recently installed my radar detector using the Radar Mount RJ11 mirror wire power cord for radar detectors. I had no problem tapping into the dome light clip with the red/red pin and black/black pin. Worked like a charm and install was fairly effortless.
I recently picked up a Dashcam that has a USB-C connection for power. I purchased the Wiring USB kit . The prongs were a bit different (slightly larger). The install went fine but no matter how much I taped / zip tied the connections, there was a power issue turning off and on after clipping the dome section back in.
Wondering, as I do not know much about the power, but could the load be too much for powering both the radar detector and the dash cam?
When I disconnect both and only use 1, it seems to not have a problem....
Also, does anyone know the clip type that is for the dome light where you would tap the black and red? I thought I read it was a 5 Pin Type A or a 7 Pin Type A.
I found this part - Pin to Pin Plug and Play Wondering if I use this for the Radar and maintain the PIN connection for the dashcam, maybe that would work if it can handle it.
11th Gen Honda Civic Radar and Dashcam install FL5 wiring assistance IMG_1533
11th Gen Honda Civic Radar and Dashcam install FL5 wiring assistance IMG_1532
11th Gen Honda Civic Radar and Dashcam install FL5 wiring assistance IMG_1534
11th Gen Honda Civic Radar and Dashcam install FL5 wiring assistance IMG_1537
11th Gen Honda Civic Radar and Dashcam install FL5 wiring assistance IMG_1541
S2K_MoZo
Zohair
Colorado
2025 CTR, GSF, Yukon, Hummer, tC, 1950 Chevy 3100
I struggled like you too. It was 5v vs. 12v mess. Just get fitDVR. It is a plug and play solution to make both work with one source.
jvperez
2025 Civic Type R (Boost Blue)
I was worried about pulling too much power from that connector so I'm only using it for the radar. Used some taps in the fuse box for the dashcams.
Evasive
Evasive
PSL Florida
2025 BB FL5
Thanks..
So basically I connect #8 below from dome light clip to clip attached to #9.. Then connect #4 to the 12v for the radar and #6 to the 5v for the dashcam. Lets hope this works!
11th Gen Honda Civic Radar and Dashcam install FL5 wiring assistance 1750799004031-kr
Evasive
Evasive
PSL Florida
2025 BB FL5
Yes. I watched quite a few videos on that and have some experience with tapping the fuse. Just did not want to start pulling pieces as I always seem to break at least 1 clip..LOL
