Roof Rack recommendations
Dealer1
Houston
2020 Civic hatchback
Hi all,
Any roof rack recommendations? I have a sub in my car and already takes all my room in the trunk. Also living in an apartment now makes me use my little cart to move lots of packages to the post office so I'm stressing for some extra room. Does anyone have experience using a roof rack on a 10+ gen civic? I am sure much hasn't changed with the frame.
Don't really have a budget since I am not sure what size or quality is best but I don't think I want anything from amazon. Thanks all
andyh96z
Andy
Fort Wayne, IN
'22 Sport Touring
I ordered one for my 11th gen ST but fortunately, my friend in the service department that was installing it asked me to come check it out before it was done (Honda accessory). It didn't seat up against roof very well and was just a hot mess. Nothing I've found online from Yakima or Thule yet.
SwiftTone
BossTown, MA
2022 Civic Si
Per another member, the Honda Accessory roof rack for the hatch does not work with the sedan.
I'm also looking for alternatives
Nefarious07
Rob
Illinois
2022 Si
sgtmorph
Long Island, New York
Back when I first saw the pdf manuals come thru the shop, I knew this OEM R.C. system would be an issue. The design just doesn't sit well with me. I feel like it could fly off with a simple yank.
rosedraws
New Hampshire
17 hatchback sport manual
Hi all,
I have the Thule rack on my 10th gen hatch sport. I believe Thule has made a new Fit Kit for the '22... which means I can't just use my one from the '17.
JCSewall
Jon
Boston
2017 Civic EX
Do you put your bikes up there? Did you buy them second hand? I am in need of something to hold my mtb.
RotoRooter247
Mason
Indianapolis
2023 Civic Si, 2023 Honda Pilot, 1986 Toyota PU
I went with the Thule recommended rack for the 23 Si. It fits nicely and doesn’t affect the sunroof or make a ton of noise. I’ll be putting my MTB up this spring.
11th Gen Honda Civic Roof Rack recommendations 0A88A3BC-24E2-404D-B0E2-CDFCF821F720
11th Gen Honda Civic Roof Rack recommendations 21337FEA-C36B-4687-8C43-EE2C25DE00E0
Nebulousbadger
united states
2022 Honda Civic Si
Also want to chip in to add some documentation for roof racks on these cars as there really aren't many pictures out there yet. I just installed a Yakima rack on mine. There is almost no increase in wind noise, and I have not noticed a negative affect on MPG so far, though I'm sure it must have some impact.
11th Gen Honda Civic Roof Rack recommendations PXL_20230606_203135069
11th Gen Honda Civic Roof Rack recommendations PXL_20230606_203141210
forrestbb
Forrest
San Mateo, CA
2018 RR CTR, Civic SI-2008 sedan
Hi Everyone,
Does anyone have a rack for their FK8?
If so, which do you prefer, Yakima or Thule? and why?
I used to have a Yakima on my Prelude and would insert paper towel cutouts under the door jam attachments so as to prevent any scratches on paint.
Is there rubber or some preventative coating on the new mounts especially in the door jam attachment areas?
Last year I saw a car that had big suction cups as mounts on their bike rack; no door jam clamp attachment s at all. Anyone see similal?
iHo
Ivan
Toronto
2022 Honda Civic Hatchback Sport
Will this roof rack fit on a 2022 Honda Civic Hatchback? Or is it different between the Sedan and Hatchback, thanks!
Ivy
Charlie
25 Pilot T, 24 Boost Blue FL5, 04 325xi
What size is ur fairing?
torquestable
Maku
Chicago
How has your experience been till this day ? Still no wind noise ? No rattle ? How is it above 80mph ?
Nebulousbadger
united states
2022 Honda Civic Si
Still have it on the car and use it quite a bit. Mileage plummets with a bike on there, but drops about 2-3mpg without a bike. I usually sit around 37-38 without the rack, but I average mid 35's with the rack. Wind noise is pretty low, not really noticeable over the noise generated by the OEM tires. With a bike attachment I have noticed added noise, I suspect mostly because of the design of the Yakima attachment traps some air against the fairing. Would probably be less noise without the fairing. One big negative for me with this rack is that I never use the sunroof with it mounted. You loose that "open" feeling, and above 30mph the wind noise is too overpowering. I use the sunroof all the time when the rack is not on the car.
For what its worth, I have thought about selling it for a seasucker.
