Which base map should I go?
jinzhonguuan
Brisbane
civic rs
Hi guys
I’m an Australian civic rs owner, I recently got a V2, I really know noting about tuning . So I have HKS catback exhaust and prl cai with maf as well.
Just wondering which tune should I use and should I adjust any settings or it’s better to not messing around.
Really appreciate if any of you guys can help!
KTuner
J.R.
Chandler, Arizona
www.KTuner.com
2017 Si
Hello from afar! All of the tunes are usable for you. If you have a RACE MAF you'll need an editable tune, so use the starters instead of the stage tunes. RACE MAF option is in the MAF Scaling under main parameters on the left.
You can also use the quick adjustments as you see fit. You'll find a bunch of info here about what others are setting those to.
