How do you jack up your Type R?
J_D
J
Montreal
Drive onto ramps then lift using centre jack point then lower onto jack stands. A bit of a pain to be honest.
Unity Performance
Humza
Toronto, ON | Buffalo, NY
unity-performance.com
Yet it seems that the consensus was that these permanently attached pinch weld blocks might fall off and cause an accident. the recommendation was rubber pads
IMHO best are the ones with magnets
https://www.amazon.com/Potauto-Universal-Grooved-Magnetic-Jacking/dp/B09T2VFK26
We would've definitely been contacted by existing customers that have purchased them over the past year if they encountered that, and so far none have. We also have these on three of our daily driven cars.
J_D
J
Montreal
Do the Verus blocks work with normal jack stands?
DmK
2025 FL5, Mx5 ND3
I just use rubber pads which came with my QuickJack no issues so far.
Easy to lift and plenty of space to work under the car...
11th Gen Honda Civic How do you jack up your Type R? tempImageXaJuH3
