⚠️ Weird noise after Clutch and Headstuds ⚠️
xxBodom
Arthur
24' Civic Si
Ill reach out to them, thanks for the reply.
Also I attached a video here of the noise, does it sound like a vacuum leak?
Just listened, are you on stock turbo?
Check all your hose clamps to make sure they're sealed and tightened properly.
Break in period for the clutch still stands though.
StockBobby
Bobby
San Diego
2022 Honda Civic SI
Yes, im on stock turbo.
I took it to the shop and had them inspect. They checked all the hoses, clamps, and loosened and retightened my exhaust from the downpipe back.
Rummaging through civic x and xi, I found some similar problems. Exhaust gasket leak appears to match my symptoms from what ive found. I can hit and maintain boost target so leaking between turbo exhaust outlet and exhaust makes sense
I think my first attempt at correction will be the turbo outlet gasket (between turbo and downpipe) this wasnt loosened and tightened by the shop and the old gasket was reused so I think it makes sense.
