Has anyone done a DIY fluid film application?
HorizonsEdge
aaron
Rockland County NY
2025 civic type r
Today was the first time I lifted up my FL5. Put it on some wheel cribbing and took a look underneath. I was surprised to see most of the under body had sheathing. I knew about the engine under tray but most of the rest is also covered in some kind of material. Can anyone tell me what it is and how hard to remove/reinstall?
Also any advice on doing a fluid film application would be great.
I am a novice, just trying to learn.
Thx
I've seen people doing fluid film and it's messy. I've never had serious rust on Honda's other than rear brake rotors and calipers. I was in New England for a long time before recently moving to AZ. I normally get a new car every 10 years and sell the old one to my son, so I see them for a few more years beyond that.
Me me! I did a fluid film application with ~4 cans on my type R in november of last year.
We threw my car up on the lift and me and my 2 friends each took a can and did passes. One of those friends has done fluid film on all of his cars, especially civics and mentioned that the two biggest problem spots are the voids of the rocker panels near the rear wheel wells, and especially the front struts.
We did not remove any of the sheathing under the car as in a worst case scenario you don't want water to get trapped under them. Instead we just coated, to the best of our ability, absolutely everything else. We put plastic bags on the braking components to make sure the lanolin didn't get on them, and basically sprayed every single bolt we could.
I highly suggest you spray the car and leave it over a few days to let the lanolin settle and "cure". Also having some kind of cover on your garage floor will save you a lot of headaches with cleanup.
I'll see if I can find some pictures, but my car didn't get rust anywhere after we sprayed it, and I drove it through multiple snowstorms and tons of road salt. The only place that I would be extra careful and maybe over spray next time is the front end links, as those developed a patina.
General advice for undercoating is to just spray the shit out of everything, use gloves, don't spray on any parts that will get hot (brakes, exhaust), spray absolutely every bolt, bushing, and joint you can find, and like I said before, have something on your floor for cleanup
HorizonsEdge
aaron
Rockland County NY
2025 civic type r
Thanks, very good information.
Ohlins8990
IL
FL5, 3G MDX
I spray a can of Blaster surface shield around the oil change leading up to winter. So far the only rust I see is the exhaust downpipe.
wrath
18 Challenger RT. 26 Civic SI (soon).
is it safe for rubber components? it says on the can that it is safe for "oil resistant" rubber. But I don't know what type of rubber is used on boots and bushings in the suspension. my car is brand new.
I sprayed about 1/2 a can of Fluid Film in key areas like the the control arms, front and rear, all the suspension bolts, basically anything you can see when you take the wheels off. and I inevitably got some on the rubber bushings and ball joint boots. I wiped off anything I got on the brake hoses. most of the rest of the underside is protected by plastic splash guards
We just avoided rubber altogether. There might have been some over spray, but I haven't seen any degradation in bushing or other rubber parts yet.
