TheKrumpet
John
St. Louis
2024 CTR CW
Had been using my vacuum but didn't like the hard plastic of the vacuum nozzle scraping up stuff in the interior. Swapped over to a cheap lint brush from Amazon and now everything is back to silky smooth.
11th Gen Honda Civic Pro-Tip: Use lint brush to keep the alcantara door panels and armrest looking fresh 1719317421801-yw
I thought I might've been the only weirdo using a similar device on the interior. I actually use a lint roller though. It's key on the black suede in the rear. It attracts dust particles like a magnet. Anyhow, glad to see I'm not alone. I also use the leaf blower on the interior to remove dust and debris.
Doskiller
Kevan
Virginia Beach, VA
2023 Civic Type R FL5
I also use an electric leaf blower on my interior ............ ;-)
TheKrumpet
TheKrumpet
John
St. Louis
2024 CTR CW
I initially tried the lint roller but I felt like the sticky was matting the suede texture. The lint brush is a lot smoooother
I might have to try it with a rubber pet hair remover brush to see if it does anything.
WeudS
Daoud
MA
2023 RR CTR, (Sold)2021 RR CTR, 2011 Tahoe LTZ
Just ordered one. Hopefully it works better than the standard brush combo.
Tickle
I haven't used the leave blower on the interior, but I use it on the exterior.
I debated the E-Go wet/dry vac because of its versatility. I just haven't pulled the trigger yet. I'll likely ask for it on my birthday.
https://egopowerplus.com/wet-dry-vacuum-power-wdv0900/
Battery operated and can suck as well as blow.
rui
NY & PT
EG6, AP1, FL5, FE1
I find that wrapping the vacuum's tip in painters tape helps prevent scratches (and also makes it easy to clean - just replace the tape as needed).
It's kind of a nightmare. I can see why they went with cloth for the US market.
Love their blowers. I primarily use them for the cars, but they're good enough for light duty around the house. Just curious, what would your use case(s) be for wet vacuuming?
Samurai1225
Chris
Cincinnati
I have a good old leather brush along with Dr. Beasley's microsuede cleaner that works very well. I like the idea of using the lint brush as well....
Tickle
It's a bad day is I need to use it.
Shingo Shoji
Jeremy
FL5 - Championship White
+1 for Dr.Beasley's. The alcanata cleaner and protector are great products.
DeathB4Dishonr
Dan
AL
If one of you guys would be kind enough to post some before and after pictures of using the roller I would greatly appreciate it.
Snmtazz70
Type R
Sonax brush works great on all, seats and doors.
