Acuity Shifter Base Bushings | Manual Transmission Only
kseriesparts
kseriesparts
Colorado
Description: The OEM base bushings on most Hondas and Acuras are made from highly compliant rubber. Thanks to leverage, the small amount of compliance the rubber adds equates to a very noticable "spongy" feeling in the shift knob during shifts. This bushing kit replaces the OEM rubber bushings with rigid 6061-T651 aluminum making for a much more decisive shift, even with a stock shifter. As an added touch, the bushings are coated in a purple Type 2 anodized finished, laser etched, and paired with class 12.9 flat-head mounting bolts
Features:
  • Reduces compliance by replacing the OEM rubber bushings with solid aluminum
  • Includes (4) upper bushings, (4) lower bushings, and (4) class 12.9 M6 mounting bolts
  • Purple anodized finish
  • Laser etched acuity logos
https://www.kseriesparts.com/merchant.mvc?Store_Code=CR&Screen=PROD&Product_Code=ACI-1914
