Axion industries L15ca upgraded Fuel system
axion_industries
Chandler, AZ
We wanted to finally post up our kits online as more people are pushing the platform and looking for more fuel once they have maxed out the factory system
We have been selling these for over 5 years with 10th gen Civic customers and ran this same kit on our 11th gen Civic with zero issues.
We offer the injectors with plug and play harness which is a good upgrade especially if your stock oem injectors have failed.
https://axionperformanceparts.com/p...-plug-n-play-harness-1?variant=51349543780640
We offer our Si fuel system which includes the larger injectors, plug and play harness and more efficient high pressure fuel pump with option to add the DW in tank pump
https://axionperformanceparts.com/p...t-upgraded-fuel-system?variant=50202701398304
We do recommend doing a ported fuel line as it will give you a little more room for tuning especially on ethanol.
https://axionperformanceparts.com/p...15-turbo-oem-feed-line?variant=48879184838944
We also have the Non Si kit which replaces the intake cam with the Si camshaft, the main let down on the Non si car is the ecu does not support the fuel pressure like the Si and would be much better with an Si swapped ecu
Any questions you can message us
11th Gen Honda Civic Axion industries L15ca upgraded Fuel system unnamed_1__81070.1672266588.1280.1280
