SpoolinFK8
Gogi
NY, NY
2024 Honda Civic Type R FL5
CAN YOU RECOMMEND A lowering spring Compatible with these wheels? thank you
If you get lowering springs and find you need a bit more camber, you have two options. Remove the alignment pin on the top hat. Or get camber plates for the OEM suspension and adjust the camber to clear.
optronix
Mid-Atlantic
Lower ball joints are also an option. I'd be curious as to what camber plates people are running on this platform. I've found some for the FK8 but most people I see doing anything with camber on FL5/DE5 are using ball joints.
lmtlsauto
lmtlsauto
LMTLS Auto
shop.lmtlsauto.com
@lmtlsauto,
Any chance for a 18x10 ET45-50 in the future?
At the moment that is not on a spec we have seen very popular.
If there is demand for it, we can make something happen
lmtlsauto
lmtlsauto
LMTLS Auto
shop.lmtlsauto.com
SiRSFL5
Orange County, CA
2025 FL5
Out of curiosity, why +39 offset and not +40 like "real" god spec? I know it's just 1mm, but with clearances already tight with +40 and 275 tires, every sliver matters, no? That's one of the only things giving me pause about these.
lmtlsauto
lmtlsauto
LMTLS Auto
shop.lmtlsauto.com
Since they are 1pc forged during manufacturing RAYS Japan tries their best to do the spec in request but just depends during their process, these came out 1mm less than the standard +40 but really it doesnt make a difference, they fit the same.
SiRSFL5
Orange County, CA
2025 FL5
Any plans on a Club Racer II Black Edition in 18x10 +40? I saw a YT video from a few years ago that had that spec.
lmtlsauto
lmtlsauto
LMTLS Auto
shop.lmtlsauto.com
CLub Racers are discontinued.
We did our last order for some 9.5 +38s that just came in but that wheel will no longer be made.
SiRSFL5
Orange County, CA
2025 FL5
Ah. Got it. Thanks for clearing that up. Last questions...
  • Are these SLs compatible with the Rays center caps?
  • If so, would any of the center caps work?
  • I know Rays doesn't make a pressed graphite colored center cap. What color center caps do people usually get for this color?
  • Finally, do you need to run hub rings with these? Or do they match the FL5 hub size?
Thanks!
lmtlsauto
lmtlsauto
LMTLS Auto
shop.lmtlsauto.com
Thanks!
    • Yes they are compatible with all the newest RAYS caps.
    • I've seen a range. Some people just run flat black, a lot run the black with red RAYS.
rondre3000
San Diego, CA
No. On the same 10" wide wheel +40 vs +39, on an FL5, will not make an appreciable difference.
