Fe1 best downpipe
j3llyfe1
Luis
Ontario Canada
2025 Honda civic si
What is the best catless downpipe for my 11th gen si?. Do i have to tune after
marcusm86
Marcus
Missouri
2025 Civic Type-R
i dont know what your options are, but for catless you are just looking for a company where you can trust the welds and the metal - theres not much to it. You dont "need" a tune but you will (probably) get a CEL and you probably wont gain anything except smell without one.
axion_industries
Chandler, AZ
ModJPB
Jason
The following are in order from highest to lowest HP gain.
Any catless - 100% need a tune to ignore p0420 error and will be stinky (sulfur/ rotten egg smell.) loudest.
27Won Catted - needs tune, slightly stinky exhaust note slight change.
PLM - cheapest, need a tune, gamble on fit/finish and durabilityand results.
MAPerformance Catted - does NOT need tune if with a defouler. Quiet. Upper shield install good, Lower heat shield doesn't not mount securely.
TSP/RV6 Catted - highest chance of not needing a tune or a defouler, least stinky, quietest but also not much of a performance boost.
*A tune is not for performance but to disable the secondary O2 sensor that can trigger a P0420 error because the gas flows to quickly and O2 changes to quickly that it thinks the catalyst is failing.
axion_industries
Chandler, AZ
Ours will make the most HP gains, really should look into the design we did unlike anything on the market.
And its 100% USA made
11th Gen Honda Civic Fe1 best downpipe IMG_0245
