TheCanadian
- Thread starter
- #1
Does anyone know what the paint code is for the FL5's oem black 19" wheels? I know the FK8 used Berlina Black from the S2000 and NSX.
agreed. Might try testing done generic colors and report backIt's more of a flat/satin black on the FL5. It's definitely not a glossy Berlina Black.
indeed, a satin... and if you cannot match the satin, i wiped it with my finger to rough up the surface of the paint to make it matchIt's more of a flat/satin black on the FL5. It's definitely not a glossy Berlina Black.
Yes, I applied the first one (Zink) listed as a base (two very thin coats after light, careful sanding with a Dremel) and then the matte finish afterwards, and with two thicker coats. If you do it, take the wheel off and do it in a dust free area. I didnāt take a beforehand picture of the curb rash after trying to extricate my car from being pinned between a curb and truck that parked so close I had to enter from the passenger side, but hereās a picture I took afterwards only because it turned out ok. The abrasion was at about 9:00 in the photo (near valve) and about 8cm x 1cm. I watched a bunch of Youtube vids and took my time (>2hrs. including curing between coats). The gouges werenāt very deep (fortunately), but ugly as hell especially after sanding. Now, itās near impossible to see, but I still know itās there!Thanks for the post! Have you tried those ?
Thanks for the update. I'm assuming this is the one you used for the base coat? I wasn't sure what you meant by "(Zink)"Yes, I applied the first one (Zink) listed as a base (two very thin coats after light, careful sanding with a Dremel) and then the matte finish afterwards, and with two thicker coats.
Nice work on this. Will use your write up and links in the near future to fix my lightly curbed (2 wheels) OEM wheels.Yes, I applied the first one (Zink) listed as a base (two very thin coats after light, careful sanding with a Dremel) and then the matte finish afterwards, and with two thicker coats. If you do it, take the wheel off and do it in a dust free area. I didnāt take a beforehand picture of the curb rash after trying to extricate my car from being pinned between a curb and truck that parked so close I had to enter from the passenger side, but hereās a picture I took afterwards only because it turned out ok. The abrasion was at about 9:00 in the photo (near valve) and about 8cm x 1cm. I watched a bunch of Youtube vids and took my time (>2hrs. including curing between coats). The gouges werenāt very deep (fortunately), but ugly as hell especially after sanding. Now, itās near impossible to see, but I still know itās there!
