For those who swapped out steering wheels
S4one
Los Angeles
FL5 Type r
Is there a guide to make sure that new steering wheel is straight?
I see on images that there is a guide pin on the bottom left of the steering wheel bolt but does that guarantee it’s straight or is there a small tolerance? From looking at diy and YouTube, it seems like it only installs one way.
Thanks
s2kdriver80
Paul
I installed a custom Swedit steering wheel in my FK8. I just made sure to have the wheel straight when I removed the old one, and to mount the new one on straight. The granularity in the wheel spline teeth spacing is large enough that you would definitely notice the difference in the angle, if you mounted the new one on crooked.
S4one
Los Angeles
FL5 Type r
Thanks for the details. The spines definitely are there but are micro, I thought it would be more pronounced.
s2kdriver80
Paul
Yea true, that's what you would think just looking at it, but keep in mind that the spline is tiny compared to the humongous steering wheel. So the seemingly small spacing between the spline teeth will translate to noticeable angle changes in the wheel. As an experiment when you put the new wheel in, you can mount it one tooth to the left or right, and you'll see a noticeable difference in angles.
