Help!!! No crank or start
jtlctr
Jake
I would definitely try clearing the code and see if it comes back immediately, and make sure the battery is at full charge.
This is a longshot, but it’s worth checking any connectors that were disconnected again. At least one member here had disconnected something, reconnected it, then had a bunch of problems. When he went back over everything, he found one of the pins bent even though the connector went back together. So I think it’s worth having your friend go through anything he unplugged, and disconnecting those plugs again to have a closer look.
2025 FL5 Civic Type R
Sounds like me when the pin bent for the wastegate actuator when I installed the PRL titanium inlet pipe on the Sport Touring. That was frustrating, everything looked right, and it was just that one thing.
jtlctr
Jake
Yes! That’s what I was remembering. I feel like I read about someone else having a similar thing happen too.
hialeahzbg
Jevel
2025 Honda Civic Type R
Yea battery was tested and I tried clearing the codes but same code immediately came back.. going to send the ecu to see if the jailbreak or ecu failed..
