High altitude, no boost, how to adjust?
amyisquiet
Amy
civic fc1
The boost value does not reach the set value
Look photos
11th Gen Honda Civic High altitude, no boost, how to adjust? nUfhOx
gtman
Mitch
2017 Cosmic Blue EX-L Sedan
KTuner is correct you aren't fully flooring it. Your TPS would show something like 113%.
What altitude are you at btw?
amyisquiet
amyisquiet
Amy
civic fc1
the is cvt
4200ft
KTuner
J.R.
Chandler, Arizona
www.KTuner.com
2017 Si
The throttle is not to the floor, as stated.
Your ECU is trying to protect your turbo from overspinning. 16.7PSI absolute at 4200ft is roughly 20PSI relative pressure. Look up relative vs absolute pressure if you don't have an understanding of the difference you're seeing here. You can still control this with the final boost table as well. Do so at your own risk and peril. Good luck.
