Hondata Losing Connection with iPhone
kmkiger
Kris
Space Coast FL
2020 Civic Si, 2023 Type R
Got my ECU back from Hondata yesterday and got it installed. I have the latest FlashPro software. Synced everything up and installed the latest tune from Phearable. I took it out on the road and when I was using the Hondata app, I noticed the app would drop the connection and not find the FlashPro. It seemed to happen most when I tried to use the Race Track Drag function. I was trying to see the time differences for 0-60 on the stock tune vs Phearable Street 2 tune. If I turned the car off and back on, it would find the Flash Pro but then drop again when I tried the Drag Function.
Has anyone else experienced this?
I plan on taking her for another spin tonight and try out some other features and see if it replicates before reaching out to Hondata.
I experienced a few drops too. Quickest and easiest fix is to unplug the Flash pro and plug it back in and fully close the app and open it back up again.
Also in the settings menu there is a slider for improved connections if its bugging out too much.
kmkiger
kmkiger
Kris
Space Coast FL
I’ve had the same issue. Fully closing and swiping out the app (not just minimizing), then reopening seems to help.
For what it’s worth, a third party developer created the Hondata app, not Hondata, and it’s always been plagued with issues. I learned this after purchasing it.
Thank you. The more I use it I am learning patience. If I give it a little time to search all devices, I can select the Flash Pro and it will stay connected.
