Infinity Design Intake and Turbo Inlet
Benny
Benny
2024 Honda Civic Type R FL5
I installed an Infinity Design Gloss Carbon intake and turbo inlet pipe. The installation was challenging and required some improvisation, as several steps in the instructions didn't match the actual parts. The sound is incredible. There is a noticable change in the throttle as well.
11th Gen Honda Civic Infinity Design Intake and Turbo Inlet Intake_Turbo_Inlet
Zpeedster M
New York
2023 Type R FL5
Are you concerned with the harness on the left side of the inlet pipe scratching up the inlet ???
Benny
Benny
Benny
I thought about that. When I installed it I wrapped it with a towel. I might wrap it with something soft. Not sure with what exactly. Any ideas?
Benny
Benny
Benny
When I installed Infinity Design's conduit piping, I wrapped with electrical tape to be safe. I thought about doing the same with the harness.
11th Gen Honda Civic Infinity Design Intake and Turbo Inlet MAF_Wirin
Zpeedster M
New York
2023 Type R FL5
I got some gold heat-reflective tape but it doesn't seem to provide any anti-abrasive qualities and it doesn't look too good taped on the inlet. Instead I got some
15 Meter Heat-resistant Flame Retardant Tape Coroplast Adhesive Cloth Tape For Car Cable Harness Wiring Loom Protection​
I have not wrapped the harness with it, probably will do it later.
SonicRay
Ray
Benny, would you mind redoing the install and filming a step by step tutorial on how you overcame adversities through the install flow? Jk, brother ?! This is by far the best looking intake and inlet on the market for the FL5. Looks amazing, and I imagine it sounds even better.
Zpeedster M
New York
2023 Type R FL5
subtitles can be changed to english
Benny
Benny
Benny
Let
I have documented the install via images. If you run into any challenges, feel free to reach out. Thank you, SonicRay. It's probably one of the best, IMO.
Zpeedster M
New York
2023 Type R FL5
I didn't do the install myself. Looks like I don't have a clamp on like you. :oops:
11th Gen Honda Civic Infinity Design Intake and Turbo Inlet IMG_20241225_152253
Benny
Benny
Benny
So they removed your clamp and didn't replace it. You need a clamp there, buddy.
Benny
Benny
Benny
You may have a split in your connector.
11th Gen Honda Civic Infinity Design Intake and Turbo Inlet Potential_Split
