Infinity Design Intake and Turbo Inlet
Benny
Benny
Benny
2024 Honda Civic Type R FL5
Thanks, will get it taped up when HPS ic pipes installed.
No worries. Keep in mind that ID provided the conduit piping for those wires as well. I installed the conduit, then applied the electrical tape.
Mobias
2024 Civic Type R, 2006 S2000
I have the intake but not the inlet. The "rubber" coupler they supply is super flimsy and tears easily. While I'm impressed overall with the intake, the install was challenging. I actually had to remove the bottom front mount from the intake to get it to fit.
Benny
Benny
Benny
Do you have images? You shouldn't have had to do that? It clips in just like the OEM housing.
11th Gen Honda Civic Infinity Design Intake and Turbo Inlet Intake_Removed~2
Mobias
I didn't take any pictures but in my case it did not fit correctly with that mount connected. Maybe because I have a bigger radiator and Acuity reverse flow hoses?
Zpeedster M
New York
2023 Type R FL5
Are you planning to put some kind of rubber tube here? Looks like the bolt can scratch up the carbon. Mine has a lot of tension on that point.
11th Gen Honda Civic Infinity Design Intake and Turbo Inlet Screenshot_2025-01-31-12-28-00-41_40deb401b9ffe8e1df2f1cc5ba480b12 (1)
Benny
Benny
Benny
I don't think it's necessary, but a slim rubber bushing could work I presume
Benny
Benny
Benny
It should have fit, even with those upgrades. TJ from AHC has all those modifications and his fit as well. I had trouble fitting it until I realized it had to fall through the ring of the ID bracket/mount.
