Lojack installed from dealer means I can't put vtt obd lock on... Keep or remove?
jcm
LA
2025 SGP FL5
Igla was 1200
Computer t13 was 1200
2400 out the door
At least for me well worth it in the LA area
22Si
IL
2025 FL5
Igla was 1200
2400 out the door
Well worth peace of mind thank you.
How long does it take for you to disable IGLA every time you start the car?
And from what I understand the compustar is just an alarm and will alert you to your cell phone as well correct?
jcm
LA
2025 SGP FL5
Compustar links up to the drone mobile app, and has tilt break and other sensors that can be set to be incredibly sensitive. The compustar remote itsself has a 3km range apparently. If you have those sensors set to a sensitive setting if someone touches the car youll pretty much know. On a medium setting closing my side mirrors sets it off. Any tilt sets it off. The drone subscription is like 24 a month or something. Also well worth it, if you know something is happening you can intervene and prevent damage, but the igla would prevent anyone other than you from doing anything with the car anyway even if they were to gain access it's not going anywhere unless they have a lift
The igla takes just a few seconds to disable the kill switch. For me it's perfect I don't mind taking a couple seconds to disable a kill switch.
The compustar remote does come with a remote start feature which is obviously pointless for us as we are manual so yea should disable that plus the igla would prevent it from working anyway so
Also drone allows you to track the location of the vehicle, the antenna has a sim card so you're going to know where it is and it's status at basically all times unless you park it and walk under a huge concrete structure
jcm
LA
2025 SGP FL5
also i should mention, there are harness implications for the igla.
you really want a professional installer for this kind of work.
highly recommend against going with any random discount shop.
best place to start would probably be Compustar Pro status installers and call around until you find one that is also highly experienced installing iglas. you can find Compustar Pro status installers on their website.
https://www.compustar.com/find-a-dealer/
you really want the wiring of something like this to have structural integrity not only for the sake of the security system but for the sake of the harness itsself.
