Mirror tilt?
Mirror tilt is handy for parallel parking, but not good for reversing out of regular parking spots. My TL mirror had a button to select tilt and I don't see a button with this kit.
I rarely parallel park, but the backup camera guidelines are handy in those situations.
WeudS
Daoud
MA
2023 RR CTR, (Sold)2021 RR CTR, 2011 Tahoe LTZ
Funny enough, one of the posters in that thread made a button to toggle it on or off for that exact reason.
https://www.integraforums.com/forum/threads/side-mirror-reverse-auto-tilt-install.51817/post-854270
nawfoo
Banned
Banned
K
Lost Wages
Integra Si
I wonder if you can retrofit a oem passenger side window and switch into the newer cars. I use mirror tilt for reverse parking because the backup lines are a little off.
Nothing
2023 CW FL5 #5044
I want this because sometimes I can't back in straight into a spot if my life depends on it.
Glad they updated the harness so I don't have to repin the connectors, but man I have to remove the a-pillar again. Might as well buy a handful of those one-use clips.
Anybody find an OE switch to use instead of a drill-in button?
Nothing
2023 CW FL5 #5044
Also, trying to follow the discussion, did the controller end up in the door or headliner where the rear view mirror is?
If you do both passenger and driver mirrors, one controller kit per door, reverse signal going through both a-pillars to the reverse signal at auto dim mirror, and then also an enable switch by the driver footwell?
